1 Reply Latest reply on Dec 7, 2009 12:11 AM by Wiouou
    Cast test apparently switches types.
    Wiouou
      I'm having a strange casting problem when using livecycle and flex client classes.
      My setup is something like this:
      at the server side:
      <destination id="service">
        <properties>
          <server>
            <actionscript-class>ServiceImpl</actionscript-class>
          </server>
        </properties>
      </destination>
      at the client side:
      public interface IService {
        function get name () : String;
        function set name (name :  String) : void;
      [Managed]
      [RemoteClass]
      public class ServiceImpl implements IService {
        public var serviceName : String;
        public function get name () : String {
          return name;
        public function set name (name : String) : void {
          this.serviceName = name;
      <mx:ComboBox id="serviceComboBox" dataProvider="{services}" labelField="name" enabled="false"/>
      Now I would expect the returned object to be of class ServiceImpl.  But apparently the labelField here doesn't exist on the object.  The object is also show in the debugger as Object@... so I guess it's a dynamic object.  First I thought this was an error on the display of the debugger but it's getting a little bit weird.  With serviceName as labelField this does work and when I put a cast test on ServiceImpl the labelField name suddenly does exist on the object.  Anyone any idea why this behaviour occurs?
