6 Replies Latest reply on Dec 8, 2009 8:21 AM by Steve Grisetti
    Freeze Frame Jittery in DVD
    Ed.Macke Level 3
      I did a freeze-frame on the last frame of a video segment. I saved the frame as the default .bmp format. I then made it 7 seconds in length with a fade-out.
      My problem is that when burned to a DVD, instead of being solid, the freeze frame jitters badly.
      It seems smooth in PRE (v7). It seems smooth when I play the exported .AVI in Windows Media Player (although it looks all interlace-y). I was going to try "Frame Blend", which fixes some jitters on time-stretched video, but that option is grayed out for stills.
      Is there something I can do to prevent the jitter? It really ruins the effect I was going for!
        • 1. Re: Freeze Frame Jittery in DVD
          Right-click on the still on your project timeline and select Field Options/Flicker Removal.
          I do this as a rule with all of my photos. Flickering is not a problem with all photos, but setting Flicker Removal is good insurance against it.
          • 2. Re: Freeze Frame Jittery in DVD
            Ed.Macke Level 3
            Criminy. You'd think I would have noticed something like that.
            Thanks, Steve, I'll give it a try...
            • 3. Re: Freeze Frame Jittery in DVD
              Ed.Macke Level 3
              Another follow-up question: When I exported, I accepted the PRE defaults of "Bitmap" (.bmp). I later noticed I could have selected other formats (TIF, GIF, etc.). Does it really make any difference, either with respect to quality or my jittery-ness problem, which format I choose?
              • 4. Re: Freeze Frame Jittery in DVD
                Not at all. Although GIFS generally don't have the color range of the other formats.
                • 5. Re: Freeze Frame Jittery in DVD
                  Ed.Macke Level 3
                  Well, good news! I got it working. My freeze frame is now rock-solid!!
                  I did the Flicker Removal - that's a good tip to know. It's now on my "cheat sheet".
                  One odd thing I noticed was when I opened the "freeze frame" .BMP that PRE had generated, the .BMP itself had interlace lines in it!  Obviously I didn't want that, so I did the freeze frame again. But this time, the exported .BMP was fine (no interlace lines).
                  I don't think I did anything differently. About the only thing I can think of is that currently the clip is Time Stretched and Frame > Blended. Maybe when I did the original freeze frame (that gave me an interlaced .BMP) it was either not Time Stretched and/or not Frame > Blended?
                  • 6. Re: Freeze Frame Jittery in DVD
                    I always recommend, when you save a Freeze Frame from a video project in Premiere Elements, that you deinterlace the picture and set it to square pixels, 640x480. That will give you the best results.
                    In version 8 you need to create a Share preset for still at these settings. (The settings are no longer available from the Freeze Frame menu.) But in previous versions of the program, if you click the Settings button after choosing to export your Freeze Frame as a photo file, you'll find an option screen where you can make the settings for frame size and pixel aspect ration. The Keyframe and Rendering page has a checkbox for setting the picture to Deinterlace.
