0 Replies Latest reply: Dec 6, 2009 8:59 PM by matt_chotin RSS
    [svn:fx-trunk] 12588: Various fixes to the sample themes as found by Peter DeHaan.
    matt_chotin Community Member
      Revision: 12588
      Revision: 12588
      Author:   mchotin@adobe.com
      Date:     2009-12-06 20:58:54 -0800 (Sun, 06 Dec 2009)
      Log Message:
      - Update the build.xml files to work in both a dev environment and in a real SDK (fixed the taskdef path for the compc task)
      - made sure Application control bar would work for all themes
      - fixed focus issue in RadioButton
      - updated skin part names for VideoPlayer to make sure that the times show
      - created emphasized skin for Spark buttons (could not easily do it for MX)
      - made sure Panel titles are bold
      - closed the gap in the Arcade ButtonBar
      QE notes: Beware of Peter DeHaan
      Doc notes: None
      Bugs: None
      Reviewer: None
      Tests run: None
      Is noteworthy for integration: Nope
      Modified Paths:
          flex/sdk/trunk/samples/themes/arcade/build.xml
          flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/ApplicationSkin.mxml
          flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/ButtonBarSkin.mxml
          flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/DefaultButtonSkin.mxml
          flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/RadioButtonSkin.mxml
          flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/VideoPlayerSkin.mxml
          flex/sdk/trunk/samples/themes/arcade/src/defaults.css
          flex/sdk/trunk/samples/themes/cobalt/build.xml
          flex/sdk/trunk/samples/themes/cobalt/src/cobalt/skins/ApplicationSkin.mxml
          flex/sdk/trunk/samples/themes/cobalt/src/cobalt/skins/PanelSkin.mxml
          flex/sdk/trunk/samples/themes/cobalt/src/cobalt/skins/RadioButtonSkin.mxml
          flex/sdk/trunk/samples/themes/cobalt/src/cobalt/skins/VideoPlayerSkin.mxml
          flex/sdk/trunk/samples/themes/cobalt/src/defaults.css
          flex/sdk/trunk/samples/themes/graphite/build.xml
          flex/sdk/trunk/samples/themes/graphite/src/defaults.css
          flex/sdk/trunk/samples/themes/graphite/src/graphite/skins/ApplicationSkin.mxml
          flex/sdk/trunk/samples/themes/graphite/src/graphite/skins/DefaultButtonSkin.mxml
          flex/sdk/trunk/samples/themes/graphite/src/graphite/skins/PanelSkin.mxml
          flex/sdk/trunk/samples/themes/graphite/src/graphite/skins/RadioButtonSkin.mxml
          flex/sdk/trunk/samples/themes/graphite/src/graphite/skins/TitleWindowSkin.mxml
          flex/sdk/trunk/samples/themes/graphite/src/graphite/skins/VideoPlayerSkin.mxml
          flex/sdk/trunk/samples/themes/zen/build.xml
          flex/sdk/trunk/samples/themes/zen/src/defaults.css
          flex/sdk/trunk/samples/themes/zen/src/zen/skins/ApplicationSkin.mxml
          flex/sdk/trunk/samples/themes/zen/src/zen/skins/DefaultButtonSkin.mxml
          flex/sdk/trunk/samples/themes/zen/src/zen/skins/PanelSkin.mxml
          flex/sdk/trunk/samples/themes/zen/src/zen/skins/RadioButtonSkin.mxml
          flex/sdk/trunk/samples/themes/zen/src/zen/skins/VideoPlayerSkin.mxml
      Added Paths:
          flex/sdk/trunk/samples/themes/cobalt/src/cobalt/skins/DefaultButtonSkin.mxml
