3 Replies Latest reply on Dec 7, 2009 4:02 AM by gregory magid
    Cannot render using XFL why ?
    gregory magid
      Hello  everyone i got a series problem, trying to render .aep file using the new XFL option in cs4
      at first AFTER EFFECTS didn't give me  trouble at all when i rendered nor png formats nor flv to flash cs4 ,
      but now i keep getting this  massage "an error occurred while opening an XFL document " and i really
      don't know why this is happening.
      i triad to low press my files , to change my comp size and to import without dragging the files directly to Flash.
      pleace halp
      Gregory Magid
        • 1. Re: Cannot render using XFL why ?
          Did you attempt to run any Adobe updates recently? If so, they may not have been applied correctly and messed up things. I opened your project on my system and it went to export just fine. Or did you set your FLV options to some strange values perhaps?
          • 2. Re: Cannot render using XFL why ?
            gregory magid Level 1
            Hey thank you for the quick reply .
            i need to say that couple of days before it really worked great but now it doesn't.
            i didn't tray to  run any Adobe updates because there are non.
            i give this prog to my friend and he couldn't open them   .
            but i really wished to have whatever is that on your computer because on main it just' stop working.
            i will tray to look up some updates for my machine.
            if you are having other suggestions i will be happy to look them up also .
            thank you wery much hope that it wil halp ^_^...
            • 3. Re: Cannot render using XFL why ?
              Hallow my  problem didn't solve itself , and yes i did
              all the necessary updates, but you right it works perfectly fine on my second PC
              I probably really changed something in the configuration of after effects or flash...
              so thanks anyway.
              have a great day
              Gregory Magid interactive designer ^_^
