3 Replies Latest reply on Oct 12, 2006 4:39 AM by Newsgroup_User
    Remote Rollover?
    bobau
      I'm beginner,
      How do I create Remote Rollovers in firework?
        • 1. Re: Remote Rollover?
          Level 7
          bobau wrote:
          > I'm beginner,
          > Thanks
          From the Fireworks help files:
          Creating a disjoint rollover
          A disjoint rollover swaps in an image under a web object when the
          pointer rolls over another web object. In response to a pointer rolling
          over or clicking a trigger image, an image appears in a different
          location on the web page. The image that is rolled over is considered
          the trigger; the image that changes is considered the target.
          As with simple rollovers that use just one slice, you first have to set
          up the trigger and target slices and the frame in which the swap image
          resides. Then you can link the trigger to the target slice with a
          behavior line.
          NOTE
          The trigger for a disjoint rollover doesn’t have to be a slice. Hotspots
          and buttons also have behavior handles that can be used to create
          disjoint rollovers. For more information on hotspots, see Creating
          hotspots. For more information about buttons, see Creating button symbols.
          1.To attach a disjoint rollover to a selected image:
          Select Edit > Insert > Slice or Hotspot to attach a slice or hotspot to
          the trigger image. NOTE This step is not necessary if the selected
          object is a button or if a slice or hotspot already covers the image.
          2.Create a new frame by clicking the New/Duplicate Frame button in the
          Frames panel.
          3.Place a second image, to be used as the target, in the new frame in
          the desired location on the canvas. You can place the image anywhere
          other than beneath the slice you created in step 1.
          4.Select the image, and then select Edit > Insert > Slice to attach a
          slice to the image.
          5.Select Frame 1 in the Frames panel to return to the frame that has the
          original image.
          6.Select the slice, hotspot, or button that covers the trigger area (the
          original image) and place the pointer over the behavior handle. The
          pointer changes to a hand.
          7.Drag the behavior handle for the trigger slice or hotspot to the
          target slice you created in step 4.
          The behavior line extends from the center of the trigger to the
          upper-left corner of the target slice, and the Swap Image dialog box opens.
          8.From the Swap Image From pop-up menu, select the frame you created in
          step 2, and click OK.
          9.Click the Preview button to preview and test the disjoint rollover.
          Linda Rathgeber [PVII] *Adobe Community Expert-Fireworks*
          http://www.projectseven.com
          Fireworks Newsgroup: news://forums.projectseven.com/fireworks/
          CSS Newsgroup: news://forums.projectseven.com/css/
          Design Aid Kits: http://www.webdevbiz.com/pwf/index.cfm
          • 2. Re: Remote Rollover?
            bobau Level 1
            I've already have the images and my cat and the mouses.
            I show you:
            <a href=" http://server6.theimagehosting.com/image.php?img=fireworks.gif" target="_blank"><img src=" http://images6.theimagehosting.com/fireworks.th.gif" border="0" title="The Image Hosting" /></a>
            • 3. Re: Remote Rollover?
              Level 7
              Don't do this in FW at all. Do it in DW.
              There is a good disjoint tutorial here -
              http://www.dw-fw-beginners.com/tutorials/drmwvr/swap_image.htm
              Murray --- ICQ 71997575
              (If you *MUST* email me, don't LAUGH when you do so!)
              http://www.dreamweavermx-templates.com - Template Triage!
              http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
              http://www.dwfaq.com - DW FAQs, Tutorials & Resources
              http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
              "bobau" <webforumsuser@macromedia.com> wrote in message
              news:egk49k$osc$1@forums.macromedia.com...
              > I show you:
