0 Replies Latest reply on Dec 7, 2009 7:01 AM by Paul Reilly
    [svn:fx-trunk] 12603: * Another weekly batch of compiler fixes.
    Paul Reilly Level 1
      Revision: 12603
      Revision: 12603
      Author:   preilly@adobe.com
      Date:     2009-12-07 07:00:47 -0800 (Mon, 07 Dec 2009)
      Log Message:
      • Another weekly batch of compiler fixes.
      QE notes: JUnit oem.ApplicationTest#testReadOnlySwf should no longer
                expect an exception to be thrown.
      Doc notes:
      Bugs: SDK-23890, SDK-24517, SDK-24466, SDK-24232, SDK-24405
      Reviewer: Corey
      Cycloner: "cyclone assist"
      Tests run: full cyclone
      Is noteworthy for integration: yes, OEM Compiler API should no longer
                                     throw exceptions.
      Code-level description of changes:
        modules/compiler/src/java/flex2/tools/oem/Application.java
          Added catch alls to build() and link().  This is part of the fix
          for SDK-23890.
        modules/compiler/src/java/flex2/tools/oem/Library.java
          Added catch alls to compile() and link().  This is part of the fix
          for SDK-23890.
          Wrapped printStackTrace() calls in a Trace.error check.
        modules/compiler/src/java/flex2/tools/oem/Toolkit.java
        modules/compiler/src/java/flex2/tools/Compc.java
        modules/compiler/src/java/flex2/tools/DigestTool.java
        modules/compiler/src/java/flex2/tools/SwcDependencies.java
        modules/compiler/src/java/flex2/tools/Optimizer.java
        modules/compiler/src/java/flex2/tools/Mxmlc.java
        modules/compiler/src/java/flex2/tools/Fcsh.java
        modules/compiler/src/java/flex2/tools/ASDoc.java
        modules/compiler/src/java/flex2/compiler/css/CssCompiler.java
        modules/compiler/src/java/flex2/tools/PreLink.java
          Modified processMainUnit() to locate and load default styles each
          time through, because new dependencies can cause new SWC's,
          potentially with defaults.css files, to become "used".  This fixes
          SDK-24517.
        modules/compiler/src/java/flex2/compiler/as3/genext/GenerativeSecondPassEvaluator.java
          Modified generateSupportCode() As3Compiler.cleanNodeFactory() so
          that the NodeFactory compound_names from one document don't spill
          over into another one.  This fixes SDK-24466.
        modules/compiler/src/java/flex2/compiler/as3/As3Compiler.java
          Added assert to parse2() to help catch places where we parse
          without calling cleanNodeFactory().
        modules/compiler/src/java/flex2/compiler/SymbolTable.java
          Added some comments to document some newly discovered FlashBuilder
          entrypoints.
        modules/compiler/src/java/flex2/compiler/mxml/Grammar.jj
          Moved guts of parseApplication() into new
          parseApplicationComponent() and modified parseInlineComponent()
          and parseDefinition() to use parseApplicationComponent() instead
          of parseUIComponent().  This fixes SDK-24232.
        modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDefLib.vm
          Modified Binding source function to use "result == null" instead
          of "!result" when doing Array singleton coercion.  This fixes
          SDK-24405.
        modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
          Direct AST generation equivalent of ClassDefLib.vm change.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-23890
          http://bugs.adobe.com/jira/browse/SDK-24517
          http://bugs.adobe.com/jira/browse/SDK-24466
          http://bugs.adobe.com/jira/browse/SDK-24232
          http://bugs.adobe.com/jira/browse/SDK-24405
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/SymbolTable.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/As3Compiler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/genext/GenerativeSecondPassEv aluator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/CssCompiler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/Grammar.jj
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDefLib.vm
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/ASDoc.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compc.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/DigestTool.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Fcsh.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Optimizer.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/PreLink.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/SwcDependencies.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Application.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Library.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Toolkit.java
