4 Replies Latest reply on Dec 7, 2009 3:11 PM by PakoCancun
    Contact Form
    PakoCancun Level 1
      Hi
      I'm making a web page and I wanna include a contact form in it so I'm making it in FLASH CS4
      Using Action Sript 3.0.
      I watched some video tutorials in YouTube in how to make the Code and PHP form.
      But when I finished the form on flash I published it in SWF and
      when I click the submit button this error shows on the OUTPUT tab:
           Error: Error #2101: The String passed to URLVariables.decode() must be a URL-encoded query string containing name/value pairs.
           at Error$/throwError()
           at flash.net::URLVariables/decode()
           at flash.net::URLVariables()
           at flash.net::URLLoader/onComplete()
      I don't know if there is an error on my code, because I upleaded it into the web to try it and I didn't recive anything
      I'm Asking for name=nombre    phone#= telefono  email=correo  and the message=mensaje
      so i'm using 4 input fields
      and this is the code I'm using:  (The php file is attached)
      // hiding some boxes used for error handling
      en.visible = false;
      ec.visible = false;
      em.visible = false;
      // build variable name for the URL Variables loader
      var variables:URLVariables = new URLVariables;
      // Build the varSend variable
      var varSend:URLRequest = new URLRequest("form_postal.php");
      varSend.method = URLRequestMethod.POST;
      varSend.data = variables;
      // Build the varLoader variable
      var varLoader:URLLoader = new URLLoader;
      varLoader.dataFormat = URLLoaderDataFormat.VARIABLES;
      varLoader.addEventListener(Event.COMPLETE, completeHandler);
      // handler for the PHP script completion and return of status
      function completeHandler(event:Event):void {
           // remove processing clip
           nombre_txt.text = "";
           telefono_txt.text = "";
           correo_txt.text = "";
           mensaje_txt.text = "";
           // Load the response from php here
           status_txt.text = event.target.data.return_msg;
      // Add event listener for submit button click
      submit_btn.addEventListener(MouseEvent.CLICK, ValidateAndSend);
      // function ValidateAndSend
      function ValidateAndSend (event:MouseEvent):void {
           // validate fields
           if(!nombre_txt.length) {
           en.visible = true;
           } else if (!correo_txt.length) {
           ec.visible = true;
           } else if (!mensaje_txt.length) {
           em.visible = true;
           } else {
                // ready the variables in our form for sending
                variables.Nombre = nombre_txt.text;
                variables.Correo = correo_txt.text;
                variables.Mensaje = mensaje_txt.text;
                variables.Telefono = telefono_txt.text;
                // Send the data to PHP now
                    varLoader.load(varSend);
           } // close else condition for error handling
      I hope someone can help
      If someone needs more info pleas tell me
      Thank you
        • 1. Re: Contact Form
          try changing:
          to
          varLoader.dataFormat = URLLoaderDataFormat.TEXT;
          • 2. Re: Contact Form
            PakoCancun Level 1
            Hi thanks but
            I changed :
                 to
            but now it prompts me with another error:
                 ReferenceError: Error #1069: Property return_msg not found on String and there is no default value.
                 at POSTAL_fla::Postal_1/completeHandler()
                 at flash.events::EventDispatcher/dispatchEventFunction()
                 at flash.events::EventDispatcher/dispatchEvent()
            and thats when the php file is in the same folder as the swf, because if I take the php file away it gives me this error:
                 Error #2044: Unhandled ioError:. text=Error #2032: Stream Error. URL:      file:///Macintosh%20HD/Users/Admin/Documents/NewFolder/Flash/Web/form_postal.php
                 at POSTAL_fla::Postal_1/frame1()
            And still i tried it on the server and I do not get any mail
            • 3. Re: Contact Form
              where's your code that references return_msg?
              • 4. Re: Contact Form
                PakoCancun Level 1
                in the PHP file
