0 Replies Latest reply on Dec 7, 2009 10:08 AM by Darrell Loverin
    [svn:fx-trunk] 12610: Fix RTE in EmbeddedFontRegistry.
    Darrell Loverin Level 4
      Revision: 12610
      Revision: 12610
      Author:   dloverin@adobe.com
      Date:     2009-12-07 10:08:38 -0800 (Mon, 07 Dec 2009)
      Log Message:
      projects/framework/src/mx/managers/SystemManager.as
      ?\226?\128?\162         I added back the "mx.styles::IStyleManager" interface. I investigated the file history and found the code was removed during frame1 cleanup.
      projects/framework/src/mx/core/EmbeddedFontRegistry.as
      ?\226?\128?\162         Fix RTE by only getting a ResourceManager instance when it is needed. The RTE happened when an RSL with embedded fonts, loading in frame1 created the registry. The ResourceManager is not ready at this point.
      projects/framework/src/mx/styles/IStyleManager2.as
      projects/framework/src/mx/styles/StyleManagerImpl.as
      ?\226?\128?\162         Removed parent setter. PARB approved.
      ?\226?\128?\162         Removed hasEventListener() check in dispatchInheritingStylesChangeEvent(). Each call to dispatchInheritingStylesChangeEvent() was already guarded with a listener check.
      QE notes: None.
      Doc notes: None.
      Bugs: SDK-24467
      Reviewer: Alex, Corey
      Tests run: checkintests, PerModuleStyles
      Is noteworthy for integration: no
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24467
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/EmbeddedFontRegistry.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/SystemManager.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/IStyleManager2.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleManagerImpl.as
