6 Replies Latest reply on Dec 9, 2009 5:12 AM by MergeThis
    Generating a pdf file in RH8
    mk8onoiml8
      Try as I might, and having read many, many, many posts, etc., etc., I am still unable to generate a pdf from my HTML RH8 file (and yes, I ask it to convert to Word, then pdf).  The following is the output message that I receive:
      Starting to build Printed Documentation...
      Printed Documentation processor 8.0.1.204
      Building Z:\BusinessCenter\Business_Center_Online_Help.doc ...
      Preparing to create Printed Documentation...
      Clearing output folder...
      Preparing files for Print Document...
      Copying files...
      Updating files...
      Finished preparing in 3 seconds.
      Preparing environment...
      Printed Document Generator Environment: Word 12.0.6504,  OS 5.1.2600, RAM 2007 M Bytes
      Building Printed Documentation 'Business Center Online Help'...
      Building Single Document 'Business_Center_Online_Help.doc'...
      Building 'Title Page'...
      Building 'Table of Contents'...
      Preparing to build chapters...
      Building 'Notice of Proprietary Information'...
      Processing 'Business Center User Guide-V 1'...
      Warning: style (p.StyleStyleStylenotesCenteredLeft18ptCenteredLeft) is not defined and will be mapped to 'Normal'.
      Completed building chapters...
      Updating list paragraphs...
      Updating images...
      Updating page numbers...
      Updating page headers...
      Updating Table of Contents...
      Saving 'Business_Center_Online_Help.doc'...
      Generating 'Business_Center_Online_Help.pdf'...
      Failed the generate PDF file 'Z:\BusinessCenter\Business_Center_Online_Help.pdf'...
      Failed to save 'Business_Center_Online_Help.doc'...
      Cleaning up temporary files...
      Internal error encountered,  Failed to generate Printed Documentation.
      Just to answer some questions before they're asked:
      1. HTML doc was originally created in RH5;
      2. Upgraded to RH8 and imported file;
      3. Tried the suggested ".dll" workaround;
      4. Trying to save pdf output locally, not on a network;
      5. Thought maybe it was hanging on the one style warning -- but doesn't seem to be the case;
      6. Have read through and followed several other helpful tips in terms of getting the pdf to generate.
      No luck, and getting frustrated.  Can anyone help?
        • 1. Re: Generating a pdf file in RH8
          RoboColum(n) Level 5
          Check that you have all the RH8 updates installed. You can check via the Help > Updates menu item. If you have done that and you still have problems, try creating a new Printed Documentation single source layout folder. Note I said "new" not "duplicate". I also just wanted to check that the actual RoboHelp project isn't sat on a network drive like your Z: drive. If it is, move it to a local drive.
          Try these and let us know how you get on.
          • Read the RoboColum(n) for a tips, tricks and musings on the Technical Communication Suite products.
          • Follow the RoboColum(n) on Twitter
          • 2. Re: Generating a pdf file in RH8
            Colum has picked up on whether or not the project is on your local drive. It is also necessary to generate to a local drive.
            Follow me @petergrainge
            • 3. Re: Generating a pdf file in RH8
              Nick@Tag Level 2
              Maybe not ideal, but I had a similar problem and the DLL fixes didn't work nor did publishing locally etc etc....
              My solution was to install a newer version of acrobat, which fixed it.
              you could even try re-installing your existing version.
              http://forums.adobe.com/thread/500866?tstart=0
              though my thread related to generating with a SWF, this was NOT the cause of the error. I never figured it out, but an acrobat update worked.
              Nick
              • 4. Re: Generating a pdf file in RH8
                mk8onoiml8 Level 1
                Hi Colum -- thanks for your reply.  I had recently checked Updates (both RoboHelp and Adobe) to make certain that I had all the latest (I do).  I created a new Printed Documentation folder, and I made sure that I was saving not to a network drive, but to my computer's C:\ drive.  Still getting the same response.  Do you have any other suggestions?
                • 5. Re: Generating a pdf file in RH8
                  mk8onoiml8 Level 1
                  Hi Peter -- thanks for your reply. I had actually picked up in some of your postings from earlier this year to be sure to generate to a local drive.  Still having the same problem; but I'm stubborn and will keep on until I find the fix.
                  • 6. Re: Generating a pdf file in RH8
                    MergeThis Level 4
                    "Warning: style (p.StyleStyleStylenotesCenteredLeft18ptCenteredLeft) is not defined and will be mapped to 'Normal'." You might want to look into that one; there's no telling how long the effects of this might linger, beyond the instance that prompted that error message.
                    You might also try a completely new layout (not a duplicate of the current layout, but an entirely new layout), generating to a completely new location. Sometimes layouts get corrupted and can't be repaired, whereas a new layout has proven to be quite beneficial in many cases here in the forum.
                    Leon
