3 Replies Latest reply on Dec 8, 2009 2:44 PM by Darrell Loverin
    Nested RSLs - Verify Error "Class not Found" Help
    viatropos Level 1
      Hi there,
      I have 2 library projects and one Application:
      TweenMax
      MyLibrary
      MyApplication
      If I make TweenMax into an RSL with these compiler arguments:
      -compute-digest=true -directory=true -output=rsl
      And I make MyLibrary into an RSL with these compiler arguments
      -compute-digest=true -allow-source-path-overlap=true -directory=true -output=rsl
      (I need that -allow-source-path-overlap=true so I can use the classes in MyApplication it seems)
      ...  And then I load the 2 libraries into MyApplication from "Flex Build Path" -> "Library Path" -> "Add Project", and I specify LinkType is RSL, and then I run MyApplication, I get the VerifyError:
      VerifyError: Error #1014: Class ..a class.. could not be found.
      I've tried adding a "crossdomain.xml" file to the root of MyLibrary and of MyApplication (at MyLibrary/crossdomain.xml or MyApplication/crossdomain.xml), with content:
      <cross-domain-policy>
          <allow-access-from domain="*" to-ports="*"/>
      </cross-domain-policy>
      But that doesn't change anything.  I am running this locally on a Mac (/Users/Lance/Documents/Flex Builder 3/MyApplication).  What am I doing wrong here?  Is it even possible to do nested RSLs like this?
      Lance
