0 Replies Latest reply on Dec 8, 2009 2:33 AM by Roberto Padilha
    Window doesn't refresh
    Roberto Padilha Level 1
      Hello everyone
      I've created myself a customized component from a TextInput, which I bind the text property with a property from an objet associated to the component (like a DataSource). I do that using BindingUtils. I have an window MDIWindow that calls another window. The first window has a datagrid and the second window is the register window for the data in the datagrid. The first time I call the second window, It works fine, I can use It and all the enabling, disabling things I do work fine. But, If I close the second window and I call It again from the firts, It stop working. I enable, disable the components and they dont't change, I change my DataSource and the text doesn't change. I debug the code and the bind is happening. I think It is just not updating the view of the components. Does anyone can help me with that?? Its freaking me out and I can't find a reason for this behavior.
      Thanks in advance.
