0 Replies Latest reply on Dec 8, 2009 2:52 AM by digisamuk
    Constant disk activity on pcd.db-journal
    digisamuk
      CS4 is causing me some issues. When my MacPro (Snow Leopard) is idle I hear my HDD constantly reading/writing something.
      After some investigation I found this little terminal line sudo fs_usage > ~/output.txt
      It creates a text file showing all disk activity and within seconds is into  hundred of megabytes (ctrl+c to stop it)
      The large bulk of this activity is the following:
      10:31:18  access            /Library/Application Support/Adobe/Adobe PCD/pcd.db-journal                      0.000004   VCStatus
      10:31:18  fstat        0.000003   VCStatus
      10:31:18  lseek        0.000001   VCStatus
      10:31:18  read        0.000004   VCStatus
      10:31:18  read        0.000003   VCStatus
      10:31:18  fcntl        0.000002   VCStatus
      10:31:18  fcntl        0.000003   VCStatus
      10:31:18  fcntl        0.000001   VCStatus
      And it repeats infinitely. I have removed the pcd.db-journal file and removed the cache.db file. Instantly the disk activity stops.
      However I can not use my CS4 apps, so I go in and activate the license again. Within minutes the activity is back to normal.
      I have repaired permissions many times, I have also used the CS4 LicenseRecovery tool. Which seemed to do its job, but as soon as I put the license back I got the same problems.
      Any ideas cos I am completely stuck. Maybe its the VCStatus. That will be the next thing I will investigate.
      And I have investigated the VCStatus issue and found this post : http://forums.adobe.com/message/2366186
      Even though I do not use Version Cue something is trying to work, when I turn on the "Show Server Status in menu bar" the activity stops and again when I uncheck the box the disk activity start immediately. I am assuming this is a bug that will be ironed out.
      Message was edited by: digisamuk
