0 Replies Latest reply on Dec 8, 2009 6:53 AM by Carol L. Frampton
    [svn:fx-trunk] 12650: TLF Build 566.
    Carol L. Frampton Level 2
      Revision: 12650
      Revision: 12650
      Author:   cframpto@adobe.com
      Date:     2009-12-08 06:53:05 -0800 (Tue, 08 Dec 2009)
      Log Message:
      TLF Build 566.
      Build 566
      • Fix 2470347, control-Z during IME session doesn't work. Now it ends the IME session on control key down.
      • Fix 2497992 whiteSpaceCollapse not property applied for inter-paragraph whitespace on text that was compiled from an mxml file.
      • Fix 2500307 TCM shouldn't have contextMenu when read-only (switch when using factory from read-select to read-only)
      QE notes:
      Doc notes:
      Bugs:
      Reviewer:
      Tests run: checkintests
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/trunk/frameworks/air-config.xml
          flex/sdk/trunk/frameworks/flex-config.xml
          flex/sdk/trunk/frameworks/libs/textLayout.swc
          flex/sdk/trunk/frameworks/projects/textLayout/ReleaseNotes.txt
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.elemen ts.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.xml
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/BuildInfo.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/container/TextContain erManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/EditManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/FlowElement. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/FlowGroupEle ment.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/SpanElement. as
      Added Paths:
          flex/sdk/trunk/frameworks/rsls/textLayout_1.0.0.566.swf
      Removed Paths:
          flex/sdk/trunk/frameworks/rsls/textLayout_1.0.0.565.swf
