4 Replies Latest reply on Dec 8, 2009 4:41 PM by Flex harUI
    How to assign constant line numbers for a DataGrid?
    niangao
      I assign the DataGrid's rowCount property to 8, which should limit the row number of the DataGrid.
      now I want  the first column of DataGrid to show the line number, which is from 1 to 8.
      this column is just for labelling the line number as a function we can
      find in any TextEditor, it is nothing about the dataProvider of the DataGrid.
      well, How can I add this column?
      any solutions? many thanks!
        • 2. Re: How to assign constant line numbers for a DataGrid?
          niangao Level 1
          Thank you for your reply, I have seen the similar code you post to me, while this is not quite right as I want.
          I want this column to just show the line number such as 1 to 8, it doen't matter how many
          rows of data I get from the dataProvider.
          The DataGrid I want is something like this:
          LineNumber         Name         age
                 1                   adobe         100
                 2                    xx               x
                 3
                 4
                 5
                 6
                 7
          I just want this LineNumber column show up there always. this column may not get from the dataProvider.
          Can I add such column in a datagrid?
          Hopefully I state my question clearly, thank you for any help.
          • 3. Re: How to assign constant line numbers for a DataGrid?
            RK... Level 3
            You can have something like this
            public class CustomGrid extends HBox {
                 private var rowGrid: DataGrid = new DataGrid();
                 private var grid: DataGrid = new DataGrid();
                 private var rowDataProvider: ArrayCollection = new ArrayCollection();
                 public function CustomGrid() {
                      super();
                 override protected function createChildren(): void {
                      super.createChildren();
                      this.setStyle("horizontalGap", "-1");
                      rowGrid.percentWidth = 10;
                      grid.percentWidth = 90;
                      this.addChild(rowGrid);
                      this.addChild(grid);
                 public function set dataProvider(value: Object): void {
                      this.grid.dataProvider = value;
                 public function get dataProvider(): Object {
                      return this.grid.dataProvider;
                 public function set rowCount(value: int): void {
                      grid.rowCount = value;
                      rowGrid.rowCount = value;
                      rowDataProvider.removeAll();
                      for (var i: int = 1; i <= value; i++) {
                           rowDataProvider.addItem({Row: i});
                      rowGrid.dataProvider = rowDataProvider;
            <custom:CustomGrid id="dgSource" dataProvider="{_acDP}" rowCount="8" >
            </custom:CustomGrid>
            [Bindable]private var _acDP:ArrayCollection
            public function init():void {
               var oItem:Object;
               _acDP = new ArrayCollection();
               oItem = {Album:"The Lost Chord", Artist:"The Moody Blues", Price:"15.99" };
               _acDP.addItem(oItem);
               oItem = {Album:"Meddle", Artist:"Pink Floyd", Price:"17.99" };
               oItem = {Album:"Trespass", Artist:"Genesis", Price:"18.99" };
            • 4. Re: How to assign constant line numbers for a DataGrid?
              Flex harUI Adobe Employee
              You can try using a labelFunction that calls getItemIndex, but that will be too slow if you have a lot of rows
              If you have lots of rows, a custom renderer might work, maybe something like:
              <mx:Component>
                   <mx:DataGridItemRenderer>
                        <mx:Script>
                        <![CDATA[
                             override public function validateNow():void
                                  if (data && parent)
                                       text = listData.owner.verticalScrollPosition + listData.rowIndex;
                                  super.validateNow();
                        </mx:Script>
                   </mx:DataGridItemRenderer>
              </mx:Component>
              Alex Harui
              Flex SDK Developer
              Adobe Systems Inc.
              Blog: http://blogs.adobe.com/aharui
