2 Replies Latest reply on Dec 9, 2009 7:10 AM by heavyboots
    Damaged Document - no Root XMLElement
    AdobeScripts Level 3
      I have few INDD files and InDesign CS3 hangs on these files when I try to duplicating any object by ALT+mouse - ALT+SHIFT+CTRL+D works fine - object is duplicated, Copy&Paste also works fine.
      Below is error message:
      Problem signature:
        Problem Event Name:    APPCRASH
        Application Name:    InDesign.exe
        Application Version:
        Application Timestamp:    48f8b023
        Fault Module Name:    XML.RPLN
        Fault Module Version:
        Fault Module Timestamp:    48f8c9f7
        Exception Code:    c0000005
        Exception Offset:    0010165f
        OS Version:    6.0.6001.
        Locale ID:    1045
        Additional Information 1:    fd00
        Additional Information 2:    ea6f5fe8924aaa756324d57f87834160
        Additional Information 3:    fd00
        Additional Information 4:    ea6f5fe8924aaa756324d57f87834160
      It is always XML.RPLN.
      What is very strange - there is NO XMLElement(s) in these files ?!?!
      I can't add any XMLElement to this file - by script or by Taggin in UI or by importing XML file - InDesign always hangs with the same message.
      INX'ing doesn't help, editing INX file and adding one missing line - nothing helps.
      Do you know of any way to fix these files ?
      here is small script which caused all trouble:
      app.documents.item(-1).xmlStories.item(-1).texts.item(-1).contents = "";
