0 Replies Latest reply on Dec 8, 2009 12:22 PM by jmurphy67
    [svn:fx-trunk] 12663: Adding the resource bundle and fat-swc targets for osmf and textlayout.
    jmurphy67 Level 1
      Revision: 12663
      Revision: 12663
      Author:   jimurphy@adobe.com
      Date:     2009-12-08 12:22:31 -0800 (Tue, 08 Dec 2009)
      Log Message:
      Adding the resource bundle and fat-swc targets for osmf and textlayout.  Also for osmf adding the doc target.  This new format that I added to the two project build files will be what we will use going forward for all projects.  I have all the other projects modified and plan on checking them in soon.  The format change will make adding new locales easier as well as adding the fat-swc target when needed.
      QE notes: no
      Doc notes: no
      Bugs: no
      Reviewer: gaurav
      Tests run: checkintests
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/trunk/frameworks/build.xml
          flex/sdk/trunk/frameworks/projects/osmf/build.xml
          flex/sdk/trunk/frameworks/projects/textLayout/build.xml
      Added Paths:
          flex/sdk/trunk/frameworks/projects/osmf/bundles/
          flex/sdk/trunk/frameworks/projects/osmf/bundles/en_US/
          flex/sdk/trunk/frameworks/projects/osmf/bundles/en_US/osmf.properties
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/textLayout.properties
      Removed Paths:
          flex/sdk/trunk/frameworks/projects/osmf/src/OSMFDocClasses.as
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/empty.properties
