1 Reply Latest reply on Dec 11, 2009 1:34 PM by Cr99
    Areaseries tooltip odd behavior
    Cr99
      I have a charting app that takes some generic Actionscript objects and unpacks them as charts.  The data is stored in a class with:
      public var point1:Object;
      public var point2:Object;
      Pretty straight forward and the app works fine except for the tooltips.  All of the tooltips display correctly for lines, plots, and columns like this:
      But not for Areaseries!  Instead with areaseries, I get:
      See the "point1" label?  Where is that coming from?  I set up all of the series the same way (or so I thought) so I can't figure out the source of this anomaly.
      Here is the relevant code:
      // genericChart is a CartesianChart
      var renderers:ArrayCollection = new ArrayCollection();
      var seriesArray:ArrayCollection = new ArrayCollection();
      var hAxis:DateTimeAxis = new DateTimeAxis();
      hAxis.displayLocalTime = true;
      hAxis.labelUnits = axis.getAxisUnits().toLowerCase();
      hAxis.labelFunction = fullTimeLabelFunction;
      // more formating of the horizontal axis
      var ar:AxisRenderer = new AxisRenderer();
      ar.axis = hAxis;
      ar.setStyle("canDropLabels", "true");
      genericChart.horizontalAxisRenderers = [ar];
      genericChart.horizontalAxis = hAxis;
      // Define vertical axis
      var vAxis:LinearAxis = new LinearAxis();
      vAxis.baseAtZero = false;
      var axr:AxisRenderer = new AxisRenderer();
      axr.axis = vAxis;
      axr.setStyle("canDropLabels", "true");
      axr.setStyle("tickPlacement", "none");
      var colRatio:Number = 1.0/axis.getSeriesList().length;
      if (colRatio == 1.0) colRatio = 1.1;
      if (type == "line") {
           var lineSeries:LineSeries = getLineSeries();
           BindingUtils.bindProperty(lineSeries, "dataProvider", ser, "pointList");
           stroke.weight = 3;
           lineSeries.verticalAxis = vAxis;
           lineSeries.horizontalAxis = hAxis;
           lineSeries.displayName = ser.name;
           lineSeries.setStyle("lineStroke", stroke);
           lineSeries.xField="point1";
           lineSeries.yField="point2";
           seriesArray.addItem(lineSeries);
      if (type == "column") {
           var columnSeries:ColumnSeries = getColumnSeries();
           BindingUtils.bindProperty(columnSeries, "dataProvider", ser, "pointList");
           columnSeries.columnWidthRatio = colRatio;
           columnSeries.verticalAxis = vAxis;
           columnSeries.displayName = ser.name;
           stroke.weight = 1;
           columnSeries.setStyle('stroke', stroke);
           columnSeries.setStyle("fill", stroke.color);
           columnSeries.xField="point1";
           columnSeries.yField="point2";
           seriesArray.addItem(columnSeries);
      if (type == "area") {
           var areaSeries:AreaSeries = new AreaSeries();
           BindingUtils.bindProperty(areaSeries, "dataProvider", ser, "pointList");
           areaSeries.verticalAxis = vAxis;
           areaSeries.horizontalAxis = hAxis;
           areaSeries.displayName = ser.name;
           var colNum:uint = new uint(new Number(ser.getColor()));
           var aColor:SolidColor = new SolidColor(colNum, 0.4);
           var aStroke:Stroke = new Stroke(col, 3,0.4);
           areaSeries.setStyle("areaStroke", aStroke);
           areaSeries.setStyle("areaFill", aColor);
           areaSeries.xField="point1";
           areaSeries.yField="point2";
           seriesArray.addItem(areaSeries);
      genericChart.series = seriesArray.toArray().reverse();
      genericChart.verticalAxisRenderers = renderers.toArray();
