0 Replies Latest reply on Dec 8, 2009 2:00 PM by Darrell Loverin
    [svn:fx-trunk] 12670: Fix build by adding modules. properties to other locales.
    Darrell Loverin Level 4
      Revision: 12670
      Revision: 12670
      Author:   dloverin@adobe.com
      Date:     2009-12-08 13:59:59 -0800 (Tue, 08 Dec 2009)
      Log Message:
      Fix build by adding modules.properties to other locales.
      QE notes: None.
      Doc notes: None.
      Bugs: SDK-20632
      Reviewer:
      Tests run:
      Is noteworthy for integration: no
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-20632
      Added Paths:
          flex/sdk/trunk/frameworks/projects/framework/bundles/da_DK/modules.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/de_DE/modules.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/es_ES/modules.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/fi_FI/modules.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/fr_FR/modules.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/it_IT/modules.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/ja_JP/modules.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/ko_KR/modules.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/nb_NO/modules.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/nl_NL/modules.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/pt_BR/modules.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/ru_RU/modules.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/sv_SE/modules.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/zh_CN/modules.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/zh_TW/modules.properties
