0 Replies Latest reply on Dec 8, 2009 2:41 PM by Peter Farland
    [svn:fx-trunk] 12673: Integrating latest FXGUtils now that TLF 566 is in trunk ( which includes a fix for TLF 2497992).
    Peter Farland Level 3
      Revision: 12673
      Revision: 12673
      Author:   pfarland@adobe.com
      Date:     2009-12-08 14:41:28 -0800 (Tue, 08 Dec 2009)
      Log Message:
      Integrating latest FXGUtils now that TLF 566 is in trunk (which includes a fix for TLF 2497992).
      Changelist: 646928
      Implementation-Title: FXG Compiler
      Implementation-Version: 1.414471
      BuildDate: 2009/12/04:03:06:24
      Notes:
      Made bitmap clipping implementation more efficient.
      Bug(s) Fixed:
      - #2491501 (Inconsistent word spacing results between MXMLC static and runtime compilation)
      - #2492932 (MXMLC gets null pointer exception on this FXG)
      - #2489341(FXG with a large BitmapImage results in a malformed SWF)
          - Added code to break down straight edges whose dx or dy exceeds 65535 twips into smaller segments.
      - #2495874 (many objects are missing in Opacity.fxg renders via MXMLC static compiler)
          - FXGUtils now ignores gradient entries of more than 15 gradient entries.
          - It logs warnings for such violations and continues processing.
      QE notes: Yes, please remove whiteSpaceCollapse="preserve" from static FXG mustella test cases or please regenerate bitmaps.
      Doc notes: N/A
      Localization: No, there are just resource strings removed in this changelist, no new strings.
      Bugs: N/A
      Reviewer: Sujata
      Tests run: Checkintests, mustella spark/core/fxg (25 failures all relating to tests that have whiteSpaceCollapse="preserve" but the reference bitmap do not expect this behavior and should be regenerated or tests modified).
      Is noteworthy for integration: Yes
      Modified Paths:
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_en.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/swf/FXG2SWFTranscoder.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/AbstractFXGNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/ContentPropertyNode.j ava
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/TextNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/fills/LinearGradientF illNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/fills/RadialGradientF illNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/filters/GradientBevel FilterNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/filters/GradientGlowF ilterNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/strokes/LinearGradien tStrokeNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/strokes/RadialGradien tStrokeNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/sax/FXGSAXScanner.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/swf/ShapeHelper.java
      Added Paths:
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/PreserveWhiteSpaceNod e.java
