0 Replies Latest reply on Dec 8, 2009 9:25 PM by cbabilotte
    create an flash application with multiple skin support
    cbabilotte
      Can anyone give me some pointers on how to include multiple skin support in Flash CS4 +ActionScript 3.
      my first idea was to create a stage with a default skin where the skin images would be in a skins/default/images directory and the path value for this different skins will be held in an config xml file.If you want to use another skin all the user will have to do is create the graphic and drop it into the skins directory under another name and update the config.xml file. I have already coded the xml parsing but not sure how I can switch from one skin to another dynamically. Any tutorial is appreciated. This is to use directly with Flash Play 10 and not with html or javascript. thanks
