4 Replies Latest reply on Dec 10, 2009 7:52 AM by Gaurav J
    asdoc how to add a custom local namespace with manifest file?
    maddec2
      Hi there,
      I use the flex 4 beta1 sdk to test the following:
      I have:
      MainScreen.mxml:
      <s:Group xmlns:fx="http://ns.adobe.com/mxml/2009"
          xmlns:mx="library://ns.adobe.com/flex/halo"
          xmlns:views="com.xyz.core.view.components.*"
          <views:AbcView id="abcView" right="20" />
      </s:Group>
      I tried to use a manifest file which seems to be how to handle this kind of situation (using ant):
          <arg line="-namespace views ${manifest.file}"/>
          <arg line="-doc-namespaces views"/>
      the manifest.xml contain the following:
      <?xml version="1.0" encoding="UTF-8"?>
      <componentPackage>
                 <component id="AbcView" class="com.xyz.core.view.components.AbcView" />
      </componentPackage>
      when I compile asdoc return the following error:
      ...MainScreen.mxml(52):  Error: Type was not found or was not a compile-time constant: AbcView
      Any idea how I can force asdoc to add/recognize AbcView.mxml ? Is my use of manifest file correct in this situation?
      Thank you in advance for your help.
      Best regards.
      maddec
        • 1. Re: asdoc how to add a custom local namespace with manifest file?
          Daniel T Employee Moderator
          Moved from Labs General Discussion to Flash Builder and Flex SDK forum.
          • 2. Re: asdoc how to add a custom local namespace with manifest file?
            Gaurav J Adobe Employee
            Do you have the source path defined? and does it contains the folder that is parent of com.xyz.core.view.components ?
            Can you post your complete call to asdoc?
            Also you can use <asdoc> ant task which is available in Flex 4. Take a look at http://gauravj.com/blog/?p=328
            Gaurav Jain
            Flex SDK Team
            http://www.gauravj.com/blog
            • 3. Re: asdoc how to add a custom local namespace with manifest file?
              maddec2 Level 1
              Hello,
              yes definitely.
              yes absolutely
              Please find below the ant task I use:
              Thank you very much for your help.
              <project name="asdoc" default="main" basedir=".">
                  Properties Definitions
                  <!-- The Location of Flex on your Computer -->
                  <property name="Flex.dir" location="C:\Program Files (x86)\Adobe\Flex Builder 3 Plug-in"/>
                  <!-- The Location of FlexSDK on your Computer -->
                  <property name="FlexSDK.dir" location="${Flex.dir}\sdks\4.0.0.7219"/>
                  <!-- <property name="FlexSDK.latest.build.dir" location="${Flex.dir}\sdks\4.0.0.12412"/> -->
                  <!-- The Location of ASDocs on your Computer -->
                  <property name="asDocs.exe" location="${FlexSDK.dir}\bin\asdoc.exe"/>
                  <!-- main path info -->
                      The Location of your Application Classes on your Computer
                      NOTE: This Path should be relative to the build.xml file.
                      NOTE: ${basedir} is an ant property that represents the directory holding the build.xml file
                      NOTE: I have encountered issues with this folder containing Spaces
                  <property name="AppClasses.dir" value='-doc-sources "${basedir}/src"'/>
                  <property name="asdoc.source.paths" value='-source-path "${basedir}/src/"' />
                  <!-- configs -->
                  <property name="asdoc.config" value='-load-config="${FlexSDK.dir}/frameworks/flex-config.xml"' />
                  <property name="sp.config" value='-load-config+="${basedir}/conditionalCompil.xml"' />
                  <!-- additional path info -->
                  <property name="source.path.srcShared" value='-source-path+="D:/analogdesign/Clients/Minsh/flash/GIT-sources/minsh-flex-widget/s rcShared"' />
                  <property name="libs.path" value='-external-library-path="${basedir}/libs"' />
                  <!-- custom components -->
                  <property name="manifest.file" location="${basedir}\ant\customCpnsManifest.xml" />
                  <!-- branding data -->
                  <property name="window.title" value='-window-title="Minsh API Documentation"' />
                  <property name="main.title" value='-main-title="Minsh API Documentation"' />
                      The Location you wish to output to on your Computer
                      NOTE: This location gets DELETED and re-generated each time the build is run
                  <property name="output.dir" location="${basedir}\output\AppDocs"/>
                  <property name="asdoc.output" value='-output="${output.dir}"' />
                  Execute the ASDoc Compile
              <target name="main" depends="clean,compile" description="full build of asdocs"/>
                  DELETE the existing output folder and files and then re-generate the output folder
              <target name="clean">
                  <delete dir="${output.dir}" failOnError="false" includeEmptyDirs="true"/>
                  <mkdir dir="${output.dir}"/>
              </target>
                  Run the ASDoc executable and generate the ASDocs to the new output folder
              <target name="compile">
                  <exec executable="${asDocs.exe}" failonerror="true">
                      <arg line="${asdoc.config}"/>
                      <arg line="${sp.config}"/>
                      <arg line="${asdoc.source.paths}"/>
                      <arg line="${AppClasses.dir}"/>
                      <arg line="${libs.path}"/>
                      <arg line="${source.path.srcShared}"/>
                      <arg line="${window.title}"/>
                      <arg line="${main.title}"/>
                      <arg line="${asdoc.output}"/>
                  </exec>
              </target>
              </project>
              Best regards.
              maddec
              • 4. Re: asdoc how to add a custom local namespace with manifest file?
                If while calling ant you pass in -debug, then you should see all arguments (that are passed in) printed on the console.
                Is the MainScreen.mxml at the root package? i.e directly under the src folder?
                -Gaurav
