8 Replies Latest reply on Dec 10, 2009 2:31 AM by nikos101
    How do add listeners to AS class
    nikos101 Level 2
      I have a singleton AS class that handles data. How do add listeners to it when My mxml files dispatch events
      I tried this:
          private function addActionListeners():void
                      systemManager.addEventListener(LogoutEvent.LOGOUT, clearData);
      but an AS class doesn't understand systemManager
        • 1. Re: How do add listeners to AS class
          Gregory Lafrance Level 6
          Make your class extend UIComponent, then you'll have access to systemManager.
          If this post answers your question or helps, please mark it as such.
          Greg Lafrance
          www.ChikaraDev.com
          Flex Development and Support Services
          • 2. Re: How do add listeners to AS class
            nikos101 Level 2
            awesome, the systemManager does appear to be null though?
            • 3. Re: How do add listeners to AS class
              nikos101 Level 2
              I call this method
              public function VO(caller:Function=null)
                          if (caller != VO.getInstance)
                              throw new Error("Singleton is a singleton class, use getInstance() instead");
                          if (VO.instance != null)
                              throw new Error("Only one Singleton instance should be instantiated");
                          //put instantiation code here
                          addActionListeners();
              • 4. Re: How do add listeners to AS class
                nikos101 Level 2
                All my components use the VO actionscript class that extends UIComponent reference it like this:
                VO.getInstance()
                maybe I need to do something like this
                private var vo = VO.getInstance
                in order to geth the VO class to have a non null systemManager?
                package models
                    import customevents.LogoutEvent;
                    import mx.collections.ArrayCollection;
                    import mx.core.UIComponent;
                    public class VO extends UIComponent
                            [Bindable]
                        public var usersResult:ArrayCollection;
                            private function clearData():void
                                clearDataValues();
                        public static function getInstance():VO
                            if (instance == null)
                                instance=new VO(arguments.callee);
                            return instance;
                • 5. Re: How do add listeners to AS class
                  paul.williams Level 4
                  I would expect the systemManager property to be set when the component is added to the display list.
                  • 6. Re: How do add listeners to AS class
                    nikos101 Level 2
                    Yes but this never gets added to the display list, it is purely a data
                    class.
                    best wishes
                    Nikos
                    • 7. Re: How do add listeners to AS class
                      Then extending UIComponent isn't the right way to go. If you want to use SystemManager as an event conduit then you'll have to find someway of injecting it into your singleton. Maybe when your application starts up.
                      • 8. Re: How do add listeners to AS class
                        nikos101 Level 2
                        All I need the data class to get is events from the components, maybe I
                        don't need to use SM
                        best wishes
                        Nikos
