0 Replies Latest reply on Dec 9, 2009 6:54 AM by Carol L. Frampton
    [svn:fx-trunk] 12714: TLF Build 567.
    Carol L. Frampton Level 2
      Revision: 12714
      Revision: 12714
      Author:   cframpto@adobe.com
      Date:     2009-12-09 06:54:27 -0800 (Wed, 09 Dec 2009)
      Log Message:
      TLF Build 567.
      Build 567
      • Fix 2500722 Empty elements inserted via MXML cause RTE
      • Add GlobalSettings.resolveFontLookupFunction - when set allows client to do late change to FontLookup setting
      QE notes:
      Doc notes:
      Bugs:
      Reviewer:
      Tests run: checkintests
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/trunk/frameworks/air-config.xml
          flex/sdk/trunk/frameworks/flex-config.xml
          flex/sdk/trunk/frameworks/libs/textLayout.swc
          flex/sdk/trunk/frameworks/projects/textLayout/ReleaseNotes.txt
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.compos e.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.contai ner.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.edit.x ml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.elemen ts.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.factor y.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.format s.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.operat ions.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.utils. xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.xml
          flex/sdk/trunk/frameworks/projects/textLayout/manifest.xml
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/BuildInfo.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/BaseCompose.a s
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/ComposeState. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/FlowComposerB ase.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/SimpleCompose .as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/StandardFlowC omposer.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/TextFlowLine. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/container/ContainerCo ntroller.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/container/TextContain erManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/ContainerFor mattedElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/FlowElement. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/FlowGroupEle ment.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/FlowLeafElem ent.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/GlobalSettin gs.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/InlineGraphi cElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/LinkElement. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/ParagraphEle ment.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/SpanElement. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/SubParagraph GroupElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/TCYElement.a s
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/TextFlow.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/factory/StringTextLin eFactory.as
      Added Paths:
          flex/sdk/trunk/frameworks/rsls/textLayout_1.0.0.567.swf
      Removed Paths:
          flex/sdk/trunk/frameworks/rsls/textLayout_1.0.0.566.swf
