1 Reply Latest reply on Dec 9, 2009 3:33 PM by forsythes
    Checking if a URL points to a valid image file.
    Gregory Lafrance Level 6
      I'm creating a media browser, pulling in image links from Google AS API
      Sometimes for some reason one of the image urls is invalid, because I get the broken image icon in my Tile container populated by a Repeater.
      How can I check to see if the url actually points to a valid image?
        • 1. Re: Checking if a URL points to a valid image file.
          forsythes Level 1
          Assuming that your HTTPService looks something like this...
          MXML
              <mx:HTTPService id="phpService" url="imageCheck.php" resultFormat="e4x" method="POST">
                  <mx:request xmlns="">
                        <formData>
                          <image>
                              <imageURL>{imageURLInput.text}</imageURL>
                           </image>
                        </formData>
                  </mx:request>
              </mx:HTTPService>
          You can always call a php file to check to see if the image exists. Then you can return the result as XML to Flex.
          PHP (imageCheck.php)
          <?php
          //Get the image URL from Flex form
          $myImage = $_POST['imageURL'];
          //Check to see if the image exists by trying to get the image size properties of it.
          $url=getimagesize($myImage);
          if(!is_array($url))
          $myImage =”notFound.jpg”;
          //Write the XML file for Flex to use
          $xml_output = "<?xml version=\"1.0\"?>\n";
          $xml_output = "<formData>";
          $xml_output = "<image>";
          $xml_output = "<imageURL>".$myImage.</imageURL>";
          $xml_output = "</image>";
          $xml_output = "</formData>";
          echo $xml_output;
