4 Replies Latest reply on Jul 6, 2008 4:47 PM by shaun000
    Converting Date from ActionScript to Java
    shaun000
      I have a Flex frontend and a Java backend. When I send an object with a date field from flex to my backend it converts the date field to a java.util.Date. The problem is that the class in java has defined the date field as a Timestamp so when the object is received as a parameter in the backend it throws an arguement type mismatch. Is there anyway a flex date value can be sent and recognised by Java as a Timestamp.
