8 Replies Latest reply on Dec 11, 2009 2:27 PM by pir897
    Timer and loop questions
    pir897
      I have a TimerEvent that updates the index of a ComboBox that loops through XML content as if they were slides.  Currently there are 6 slides in my XML file but when I run the presentation it only goes through 3 before looping back to the first slide.  I shuffled the XML slide order and it still only showed the 3 so I don't believe there is a problem in the XML.  I can also test the data and get a response with all of the content in FlashBuilder.
      How do I get it go go through the entire XML file before looping back to the first.  Could it be that it is only loading the first 3 before the application begins playing?
      The XML data is pulled through an httpService that was created via the Data/Services tab.
      Forgive me, this originally started as a drop down list before I converted to a combo box.  The id for the combo box is still "dropDownList".
      The AS
      private var timer:Timer;
      private function init():void
          timer = new Timer(2500);
          timer.addEventListener(TimerEvent.TIMER, onTimer);
          timer.start();
      private function onTimer(evt:TimerEvent):void
          var idx:uint = dropDownList.selectedIndex;
          var max:uint = dropDownList.numChildren;
          var newIdx:uint = ++idx % max;
          dropDownList.selectedIndex = newIdx;
      Some MXML
      <fx:Binding source="dropDownList.selectedItem as Slide" destination="slide"/>
      <mx:ComboBox editable="true"
          x="10" y="10"
          id="dropDownList"
          creationComplete="dropDownList_creationCompleteHandler(event)"
          dataProvider="{getSlidesResult.lastResult}"
          labelField="number"
          visible="false" />
      Once this is resolved I need to find answers to two more problems:
      1. How can I refresh the XML data at the end of each loop.  The XML file is going to be constantly updated.
      2. There will be some video content.  I would like to be able to cancel the timer for slides with a video and add a listener that forwards to the next slide when the video is complete.
        • 1. Re: Timer and loop questions
          Flex harUI Adobe Employee
          var max:uint = dropDownList.dataProvider.length;
          You can call send() on your HTTPService to get data again.  If the url does not change, you might need to add a fake parameter to the url that does change so the browser won't serve the old one from the cache.
          You could create a custom event that fires from both the timer and the video to indicate that it is time to advance. Shut off the timer if you are playing a video.
          Alex Harui
          Flex SDK Developer
          Adobe Systems Inc.
          Blog: http://blogs.adobe.com/aharui
          • 2. Re: Timer and loop questions
            pir897 Level 1
            The dataProvider.length worked perfectly.
            Can you dumb down the HTTPService suggestion a bit for a guy who lives in a world of CSS & HTML?  Do I need to create a listener to know when I've reached the end of the XML list?  If so, where do I add it.  The HTTPService info is in a package named services.slidesservice.  That AS file has this function
                 public function getSlides() : AsyncToken
                      var _internal_operation:AbstractOperation = _serviceControl.getOperation("getSlides");
                      var _internal_token:AsyncToken = _internal_operation.send() ;
                      return _internal_token;
            Is this the right send operation?
            Thanks for your help.
            • 3. Re: Timer and loop questions
              pir897 Level 1
              I answered the video portion of my question by adding in some event handlers to the VideoPlayer.
              protected function VideoPlayer_readyHandler(event:VideoEvent):void
                  timer.stop();
              protected function VideoPlayer_completeHandler(event:VideoEvent):void
                  timer.start();
              Now I need to unload the FLV in the completeHandler too.  I know how to do that in AS2 in an FLVPlayback, but it appears the VideoPlayer is different.
              • 4. Re: Timer and loop questions
                You'll know you hit the end when max == selectedIndex.
                I don't use HTTPService much so other folks may better help you.  Where is the code that gets the original data set?
                Alex Harui
                Flex SDK Developer
                Adobe Systems Inc.
                • 5. Re: Timer and loop questions
                  rfrishbe Level 3
                  To unload content in the new Spark VideoPlayer, you can just set the source to null or set it to another valid video source and the old one should unload.
                  -Ryan
                  • 6. Re: Timer and loop questions
                    pir897 Level 1
                    That worked.  I also had success using VideoPlayer.visible=false, but I'll stick with your version since I don't have to make it visible again later.
                    • 7. Re: Timer and loop questions
                      pir897 Level 1
                      SlidesService.as
                      package services.slidesservice
                      public class SlidesService extends _Super_SlidesService
                      import mx.rpc.AsyncToken;
                      import com.adobe.fiber.core.model_internal;
                      import mx.rpc.AbstractOperation;
                      import valueObjects.Slide;
                      import com.adobe.fiber.services.wrapper.HTTPServiceWrapper;
                      import mx.rpc.http.HTTPMultiService;
                      import mx.rpc.http.Operation;
                      import com.adobe.serializers.xml.XMLSerializationFilter;
                      [ExcludeClass]
                      internal class _Super_SlidesService extends HTTPServiceWrapper
                          private static var serializer0:XMLSerializationFilter = new XMLSerializationFilter();
                          // Constructor
                          public function _Super_SlidesService()
                              // initialize service control
                              _serviceControl = new HTTPMultiService("");
                               var operations:Array = new Array();
                               var operation:Operation;
                               var argsArray:Array;
                               operation = new Operation(null, "getSlides");
                               operation.url = "http://xxxx/slides1.xml";
                               operation.method = "GET";
                               operation.serializationFilter = serializer0;
                               operation.properties = new Object();
                               operation.properties["xPath"] = "/::slide";
                                 operation.resultElementType = valueObjects.Slide;
                               operations.push(operation);
                               _serviceControl.operationList = operations;
                               model_internal::initialize();
                             * This method is a generated wrapper used to call the 'getSlides' operation. It returns an AsyncToken whose
                             * result property will be populated with the result of the operation when the server response is received.
                             * To use this result from MXML code, define a CallResponder component and assign its token property to this method's return value.
                             * You can then bind to CallResponder.lastResult or listen for the CallResponder.result or fault events.
                            * @see mx.rpc.AsyncToken
                            * @see mx.rpc.CallResponder
                            * @return an AsyncToken whose result property will be populated with the result of the operation when the server response is received.
                      • 8. Re: Timer and loop questions
                        pir897 Level 1
                        I just want to make sure you saw my reply.
