0 Replies Latest reply on Dec 10, 2009 10:48 AM by CannotCompute
    Problems with CreationPolicy
    CannotCompute Level 1
      I have the creationPolicy set equal to 'none' on some panels.  Then I have a button that is on the same level as the panel.  If i comment out the button, then when i do createComponentsFromDescriptors(); the panel comes up just fine.  If the button is not commented out, then
      createComponentsFromDescriptors(); does nothing.  Can anyone explain this?
      works fine:
      <mx:Script> <![CDATA[
      import mx.controls.Alert;
      import effects.SpecialEffects;
      import mx.events.ResizeEvent;
      public function init():void
      this.addEventListener(ResizeEvent.RESIZE, resizeHandler);
      view.createComponentsFromDescriptors();
      geh.createComponentsFromDescriptors();
      private function resizeHandler(e:ResizeEvent):void
      trace(e.type);
      </mx:Script>
      <components:UI_Floorplan id="view" creationPolicy="none" />
      <components:UI_GlobalEventHandler id="geh" creationPolicy="none"/>
      <mx:HTTPService id="configData" url="fx.xml" fault="Alert.show('Error Loading XML');" result="fxdata=event.result.root.config; init();"/>
      <mx:ArrayCollection id="fxdata"/>
      <!--<mx:Button id="toggleBackend" width="4" height="4" right="0" bottom="0" click="geh.changeDisplay();"/>-->
      problems:
      trace(e.type);
      </mx:Script>
