1 Reply Latest reply on Dec 11, 2009 10:42 PM by David_F57
    Timer & Fade effect
    pir897
      One more question then I'm done for the day.
      I'm using a timer to change the index on my combobox (I'm sure there's a better way but its working) which is pulling slide data from an XML file.  I would like to crossfade between slides.  Is see there is a spark fade, but I'm unsure how to apply it to each element to work with the timer.
      Timer code:
      private var timer:Timer;
      private function init():void
          timer = new Timer(5000);
          timer.addEventListener(TimerEvent.TIMER, onTimer);
          timer.start();
      private function onTimer(evt:TimerEvent):void
          var idx:uint = dropDownList.selectedIndex;
          var max:uint = dropDownList.dataProvider.length;
          var newIdx:uint = ++idx % max;
          dropDownList.selectedIndex = newIdx;
      The comboBox (yes, it used to be a drop down list)
      <mx:ComboBox editable="true"
          x="10" y="10"
          id="dropDownList"
          creationComplete="dropDownList_creationCompleteHandler(event)"
          dataProvider="{getSlidesResult.lastResult}"
          labelField="number"
          visible="false" />
      The items that need to have the fade effect are mx:Text, s:TextArea, mx:Image, & s:VideoPlayer.  Each has a unique ID.
