Revision: 12813
Revision: 12813
Author: rfrishbe@adobe.com
Date: 2009-12-10 14:55:13 -0800 (Thu, 10 Dec 2009)
Log Message:
Taking a little bit of a risk, but setting fontLookup explicitly to "device" should fix the issue the build machine was having. Gaurav helped me confirm this on the cyclone machine which was seeing the same failure.
QE notes: -
Doc notes: -
Bugs: -
Reviewer: -
Tests run: checkintests
Is noteworthy for integration: No
Modified Paths:
flex/sdk/trunk/frameworks/tests/basicTests/spark/scripts/StyleManagerTestScript.mxml
flex/sdk/trunk/frameworks/tests/basicTests/spark/scripts/TextInputTestScript.mxml
flex/sdk/trunk/frameworks/tests/basicTests/spark/views/StyleManagerTests.mxml
flex/sdk/trunk/frameworks/tests/basicTests/spark/views/TextInputTests.mxml
