0 Replies Latest reply on Dec 10, 2009 5:54 PM by kevinklin
    [svn:fx-trunk] 12821: Follow-up to SDK-24574.
    kevinklin Adobe Employee
      Revision: 12821
      Revision: 12821
      Author:   klin@adobe.com
      Date:     2009-12-10 17:53:44 -0800 (Thu, 10 Dec 2009)
      Log Message:
      Follow-up to SDK-24574. Add try-catch block to two other places where we use bitmapData.draw(). In this case, we allow the bitmaps to remain null. In this failure case, the flag, hasBitmaps, is set and the shader in the AnimateTransitionShaderInstance is not created. This allows the effect to finish, just without input from the shader since it could not capture the bitmaps.
      QE notes: No
      Doc notes: No
      Bugs: SDK-24574
      Reviewer: Chet
      Tests run: checkintests
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24574
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/AnimateTransitionShader.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/supportClasses/AnimateTransiti onShaderInstance.as
