5 Replies Latest reply on Dec 15, 2009 4:10 AM by Wiouou
    How to use classes of packages in flex <mx:Script/> or <mxml/>
    Ankurwahi
      Hi.I am just learning Flex using Flex Builder 3 facing one problem,
      Suppose I declare one package with name alert.as
      package
      import mx.controls.Alert;
      public class alert
      public function alertBtn()
      Alert("Hello btn 1");
      Now in want to use the function in mxml that I declared in a package.
      <mx:Button label="btn1" click="alertBtn();"  />
      I have few questions
      1)How to Import the class alert.as in <mx:Script> and where should i store the file alert.as in the directory folder of flex?
      2)How to call the function alertBtn() when btn1 is clicked.
      Thanks so much!
      Regards
      Ankur
        • 1. Re: How to use classes of packages in flex <mx:Script/> or <mxml/>
          Gregory Lafrance Level 6
          import alert;     if in same directory as mxml file
          import myClasses.alert;      if in directory my classes
          often classes are places in a directory structure lie this:
          com.yourCompany.classes.PURPOSE
          where PURPOSE might be "events" etc.
          If your function is static, you can call it with alert.alertBtn()
          If not static, then create an instance
          private var myinstance:alert = new alert();
          <mx:Button label="btn1" click="myInstance.alertBtn();"  />
          If this post answers your question or helps, please mark it as such.
          Greg Lafrance
          www.ChikaraDev.com
          Flex Development and Support Services
          • 2. Re: How to use classes of packages in flex <mx:Script/> or <mxml/>
            Ankurwahi Level 1
            Hello Greg Lafrance
            Thanks for Ur Help!Your answer is helpful and I have marked it helpful!
            I want to ask You One more thing.Suppose there is one button
            <mx:Button id="btn1" >
            In a <script> tag we can access the btn1 directly like
            btn1.Label="button1";
            I want to use the button having id=btn1 inside the package then what should I need to do?
            do I need do declare the instance of btn1 like this
            var btn_1:btn1;
            Ankur
            • 3. Re: How to use classes of packages in flex <mx:Script/> or <mxml/>
              I imagine what you really mean is you want to access the button in a class, not in a package.
              If an instance of the button exists in the main MXML file for example myBtn, you can access it with parentApplication.myBtn if the class where you have parentApplication.myBtn has an instance in the main MXML file (hence the main app is the parentApplication.
              If you just want to have an instance of a component in a class, as long as you import the component
              import mycomponents.mysubFolder.MyFancyComponent;
              then you can create an instance of the component.
              Not exactly clear on your situation.
              Greg Lafrance
              www.ChikaraDev.com
              • 4. Re: How to use classes of packages in flex <mx:Script/> or <mxml/>
                Ankurwahi Level 1
                Hi Greg.I think I was not able to clear my problem properly.Let me try this time again.
                What I wanted to do was that in the below written code I have the full access of the id=panel1 in the  script tag .This works properly.
                <?xml version="1.0"?>
                <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
                <mx:Script><![CDATA[
                import flash.display.Sprite;
                import mx.core.UIComponent;
                private function addChildToPanel():void {
                var circle:Sprite = new Sprite();
                circle.graphics.beginFill(0xFFCC00);
                circle.graphics.drawCircle(0, 0, 20);
                var c:UIComponent = new UIComponent();
                c.addChild(circle);
                panel1.addChild(c);
                ]]></mx:Script>
                <mx:Panel id="panel1" height="100" width="100"/>
                <mx:Button id="myButton" label="Click Me" click="addChildToPanel();"/>
                </mx:Application>
                This above functionality when I tried to do using class Outside the code ,its not working !
                Here is with the package:-
                But suppose I make One package
                package
                class getPanel extends Sprite
                public function addChildToPanel():void {
                c.addChild(circle);
                panel1.addChild(c);
                          }//class
                                    }//package
                Now in MXML
                import getPanel;
                ]]></mx:Script>
                <mx:Button id="myButton" label="Click Me" click="getPanel.addChildToPanel();"/>
                </mx:Application>
                So My problem is that this code doesnt do anything.
                Neither the addChild function is working in it ,Nor the Panel1 is accessible here.
                Can u pls help me here.
                Ankur
                • 5. Re: How to use classes of packages in flex <mx:Script/> or <mxml/>
                  Wiouou Level 1
                  The problem is that you imported the class, meaning the compiler knows where to get the code but you don't use this code.  There is no variable of the type getPanel in your code.  Either you place a tag getPanel there with a custom namespace or you declare variable of that type in your mx:Script tag.
                  But your code would still fail because you reference a variable panel1 in that method.  In your first code sample this would work because the method is known within the class (your component will be compiled into an actionscript class).  In the second sample your variable name hasn't been declared inside the class, so you should provide it one way or another.  You can do this by adding a panel1 : Panel parameter.  In this case don't forget to either instantiate a variable of type getPanel in your component or making the addChild.. method static so you can access it at class level instead of object level.
