0 Replies Latest reply on Dec 11, 2009 6:13 AM by Carol L. Frampton
    [svn:fx-trunk] 12845: TLF Build 569.
    Carol L. Frampton Level 2
      Revision: 12845
      Revision: 12845
      Author:   cframpto@adobe.com
      Date:     2009-12-11 06:13:32 -0800 (Fri, 11 Dec 2009)
      Log Message:
      TLF Build 569.
      Jim seems to have modified build.xml for ASDocs so rather than wiping it out which I almost did not realizing it wasn't TLF's version I hand moved the one change over:
           <keep-as3-metadata>IMXMLObject</keep-as3-metadata>
      Build 569
      • Fix Watson 2504656, IME left in uncommitted state after application is deactivated. Fix is to call compositionAbandoned() on the deactivate event.
      • Fix for 2504162, Change mxml compilation of id property.
      • Fix 2503331 TextLine Recycling Issues
      Build 568
      • Fix 2504032 TCM contextMenu when using the factory and READ_SELECT should not enable the editi clipboard items such as cut and paste
      QE notes:
      Doc notes:
      Bugs:
      Reviewer:
      Tests run: checkintests
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/trunk/frameworks/air-config.xml
          flex/sdk/trunk/frameworks/flex-config.xml
          flex/sdk/trunk/frameworks/libs/textLayout.swc
          flex/sdk/trunk/frameworks/projects/textLayout/ReleaseNotes.txt
          flex/sdk/trunk/frameworks/projects/textLayout/build.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.contai ner.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.edit.x ml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.elemen ts.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.xml
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/BuildInfo.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/BaseCompose.a s
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/ComposeState. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/FlowComposerB ase.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/SimpleCompose .as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/TextFlowLine. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/container/ContainerCo ntroller.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/container/ISandboxSup port.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/container/TextContain erManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/EditManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/BackgroundMa nager.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/FlowElement. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/TextFlow.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/factory/TextFlowTextL ineFactory.as
          flex/sdk/trunk/frameworks/projects/textLayout/tlf.properties
      Added Paths:
          flex/sdk/trunk/frameworks/rsls/textLayout_1.0.0.569.swf
      Removed Paths:
          flex/sdk/trunk/frameworks/rsls/textLayout_1.0.0.567.swf
