0 Replies Latest reply on Dec 11, 2009 6:46 AM by Paul Reilly
    [svn:fx-trunk] 12848: * Another batch of compiler fixes.
    Paul Reilly Level 1
      Revision: 12848
      Revision: 12848
      Author:   preilly@adobe.com
      Date:     2009-12-11 06:46:13 -0800 (Fri, 11 Dec 2009)
      Log Message:
      • Another batch of compiler fixes.
      QE notes:
      Doc notes:
      Bugs: SDK-24472, SDK-14213, SDK-24555
      Reviewer: Corey, Mike M.
      Cycloner: Gaurav
      Tests run: full cyclone
      Is noteworthy for integration: Yes, the SwcDynamicArchive.java change
                                     should reduce memory use in FB.
      Code-level description of changes:
        modules/swfutils/src/java/flash/localization/LocalizationManager.java
          Added "locale" variable and initialized it to Locale.getDefault().
          Replaced use of Locale.getDefault() with "locale" variable.
          Added setLocale().
        modules/antTasks/src/flex/ant/MxmlcTask.java
        modules/antTasks/src/flex/ant/CompcTask.java
          Added user-locale option.
        modules/compiler/src/java/flex2/configuration_en.properties
          Added user-locale description.
        modules/compiler/src/java/flex2/tools/oem/internal/OEMUtil.java
          Modified setupLocalizationManager() to only create a new
          LocalizationManager if one hasn't been setup already.
          Removed "finally { clean() }" from all local methods.  It was
          clearing out the LocalizationManager, which was causing the
          configured locale to be lost.  flex2.tools.oem.Application and
          flex2.tools.oem.Library already call OEMUtil.clean(), so it
          doesn't need to be called here.
        modules/compiler/src/java/flex2/compiler/common/Configuration.java
          Added cfgUserLocale().
        modules/compiler/src/java/flex2/compiler/config/ConfigurationException_en.properties
          Added UserLocaleNotAvailable message.
        modules/compiler/src/java/flex2/compiler/config/ConfigurationException.java
          Added UserLocaleNotAvailable class.
        compiler/src/java/flex2/compiler/media/FontTranscoder.java
          Modified getURL() to handle fonts in a SWC subdirectory.  This
          fixes SDK-24555.
        compiler/src/java/flex2/compiler/swc/SwcDynamicArchive.java
          Modified save() to close and null out "out".  This fixes SDK-24472.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24472
          http://bugs.adobe.com/jira/browse/SDK-14213
          http://bugs.adobe.com/jira/browse/SDK-24555
      Modified Paths:
          flex/sdk/trunk/modules/antTasks/src/flex/ant/CompcTask.java
          flex/sdk/trunk/modules/antTasks/src/flex/ant/MxmlcTask.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/Configuration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException.jav a
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_en. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/media/FontTranscoder.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcDynamicArchive.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_en.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/OEMUtil.java
          flex/sdk/trunk/modules/swfutils/src/java/flash/localization/LocalizationManager.java
