0 Replies Latest reply on Dec 11, 2009 6:55 AM by Paul Reilly
    [svn:fx-trunk] 12849: * In order to fix SDK-24527, I had to revert
    Paul Reilly Level 1
      Revision: 12849
      Revision: 12849
      Author:   preilly@adobe.com
      Date:     2009-12-11 06:55:28 -0800 (Fri, 11 Dec 2009)
      Log Message:
      • In order to fix SDK-24527, I had to revert
        AbstractSyntaxTreeUtil.java revisions 10220 and 10459.  The good
        news is that SDK-22607 and SDK-22027 remain fixed.
      QE notes: please confirm that SDK-22607 and SDK-22027 remain fixed and
                that the test case for SDK-24527 reports the same error with
                -keep set to true and false.
      Doc notes:
      Bugs: SDK-24527
      Reviewer: Corey
      Cycloner: Gaurav
      Tests run: full cyclone
      Is noteworthy for integration: No
      Code-level description of changes:
         asc/src/java/macromedia/asc/parser/Parser.java
           Made match() public, so AbstractSyntaxTreeUtil can call it.
         compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
           Modified parse() to no longer wrap the text in curly braces and
           instead match EOS_TOKEN after calling parseDirectives().
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24527
          http://bugs.adobe.com/jira/browse/SDK-22607
          http://bugs.adobe.com/jira/browse/SDK-22027
      Modified Paths:
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/Parser.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
