0 Replies Latest reply on Dec 11, 2009 11:58 AM by Jason Szeto
    [svn:fx-trunk] 12859: Masking bugs
    Jason Szeto Level 3
      Revision: 12859
      Revision: 12859
      Author:   jszeto@adobe.com
      Date:     2009-12-11 11:57:39 -0800 (Fri, 11 Dec 2009)
      Log Message:
      Masking bugs
      SDK-24646 - Masking element on RIchText should inherit the target group's coordinate space
      SDK-24559 - Using a mask with RichText doesn't work if you are using an MX Application
      Fixed masking in RichText. The mask was not properly parented. Since we don't need to fake the parenting chain, we pass a null parent to MaskUtil.applyMask
      Removed mask.parent check from MaskUtil.applyMask. It doesn't need this check.
      Restored the mask initialization order in GraphicElement. Moved the addChild call back before the MaskUtil.applyMatirx call.
      Updated GroupBase to call MaskUtil.applyMask.
      QE notes: None
      Doc notes: None
      Bugs: SDK-24646, SDK-24559
      Reviewer: Ryan
      Tests run: checkintests, group, primitives
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24646
          http://bugs.adobe.com/jira/browse/SDK-24559
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/RichText.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/GroupBase.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/GraphicEleme nt.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/utils/MaskUtil.as
