6 Replies Latest reply: Jun 25, 2010 9:59 PM by craigmurray100 RSS
    invalid application descriptor: descriptor version does not match runtime version
    BarryGee
      Hi.
      I have writen a very simple AIR app. Its not really an app just a button on the stage in flex2 as I want to try packaging it up as an air app from the command line. When i use adl to do this i get the following error.
      I have just downloaded the latest version of AIR 1.0.1 and still have no joy even when i change <application xmlns=" http://ns.adobe.com/air/application/1.0"> to <application xmlns=" http://ns.adobe.com/air/application/1.0.1">
      The code for my app is below, i woudl very much appreciate a little advice as to where i am going wrong.
      Many thanks
      Barry.
      test-app.xml (descriptor file)
      <?xml version="1.0" encoding="UTF-8"?>
      <!-- Adobe AIR Application Descriptor File Template.
      Specifies parameters for identifying, installing, and launching AIR applications.
      See http://www.adobe.com/go/air_1.0_application_descriptor for complete documentation.
      xmlns - The Adobe AIR namespace: http://ns.adobe.com/air/application/1.0
      The last segment of the namespace specifies the version
      of the AIR runtime required for this application to run.
      minimumPatchLevel - The minimum patch level of the AIR runtime required to run
      the application. Optional.
      <!-- The application identifier string, unique to this application. Required. -->
      <id>test application</id>
      <!-- Used as the filename for the application. Required. -->
      <filename>test</filename>
      <!-- The name that is displayed in the AIR application installer. Optional. -->
      <name>test app</name>
      <!-- An application version designator (such as "v1", "2.5", or "Alpha 1"). Required. -->
      <version>v1</version>
      <!-- Description, displayed in the AIR application installer. Optional. -->
      <!-- <description></description> -->
      <!-- Copyright information. Optional -->
      <!-- <copyright></copyright> -->
      <!-- Settings for the application's initial window. Required. -->
      <initialWindow>
      <!-- The main SWF or HTML file of the application. Required. -->
      <!-- Note: In Flex Builder, the SWF reference is set automatically. -->
      <content>test.swf</content>
      <!-- The title of the main window. Optional. -->
      <!-- <title></title> -->
      <!-- The type of system chrome to use (either "standard" or "none"). Optional. Default standard. -->
      <!-- <systemChrome></systemChrome> -->
      <!-- Whether the window is transparent. Only applicable when systemChrome is false. Optional. Default false. -->
      <!-- <transparent></transparent> -->
      <!-- Whether the window is initially visible. Optional. Default false. -->
      <!-- <visible></visible> -->
      <!-- Whether the user can minimize the window. Optional. Default true. -->
      <!-- <minimizable></minimizable> -->
      <!-- Whether the user can maximize the window. Optional. Default true. -->
      <!-- <maximizable></maximizable> -->
      <!-- Whether the user can resize the window. Optional. Default true. -->
      <!-- <resizable></resizable> -->
      <!-- The window's initial width. Optional. -->
      <!-- <width></width> -->
      <!-- The window's initial height. Optional. -->
      <!-- <height></height> -->
      <!-- The window's initial x position. Optional. -->
      <!-- <x></x> -->
      <!-- The window's initial y position. Optional. -->
      <!-- <y></y> -->
      <!-- The window's minimum size, specified as a width/height pair, such as "400 200". Optional. -->
      <!-- <minSize></minSize> -->
      <!-- The window's initial maximum size, specified as a width/height pair, such as "1600 1200". Optional. -->
      <!-- <maxSize></maxSize> -->
      </initialWindow>
      <!-- The subpath of the standard default installation location to use. Optional. -->
      <!-- <installFolder></installFolder> -->
      <!-- The subpath of the Windows Start/Programs menu to use. Optional. -->
      <!-- <programMenuFolder></programMenuFolder> -->
      <!-- The icon the system uses for the application. For at least one resolution,
      specify the path to a PNG file included in the AIR package. Optional. -->
      <!-- <icon>
      <image16x16></image16x16>
      <image32x32></image32x32>
      <image48x48></image48x48>
      <image128x128></image128x128>
      </icon> -->
      <!-- Whether the application handles the update when a user double-clicks an update version
      of the AIR file (true), or the default AIR application installer handles the update (false).
      <!-- <customUpdateUI></customUpdateUI> -->
      <!-- Whether the application can be launched when the user clicks a link in a web browser.
      <!-- <allowBrowserInvocation></allowBrowserInvocation> -->
      <!-- Listing of file types for which the application can register. Optional. -->
      <!-- <fileTypes> -->
      <!-- Defines one file type. Optional. -->
      <!-- <fileType> -->
      <!-- The name that the system displays for the registered file type. Required. -->
      <!-- <name></name> -->
      <!-- The extension to register. Required. -->
      <!-- <extension></extension> -->
      <!-- The description of the file type. Optional. -->
      <!-- The MIME type. Optional. -->
      <!-- <contentType></contentType> -->
      <!-- The icon to display for the file type. Optional. -->
      <!-- <icon>
      </icon> -->
      <!-- </fileType> -->
      <!-- </fileTypes> -->
      </application>
      test.mxml
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute">
      <mx:Button x="201" y="167" label="Hello AIR!"/>
      </mx:Application>
