0 Replies Latest reply on Dec 11, 2009 3:52 PM by kevinklin
    [svn:fx-trunk] 12870: Couple of minor fixes including SDK-24627 and SDK-24628.
    kevinklin Adobe Employee
      Revision: 12870
      Revision: 12870
      Author:   klin@adobe.com
      Date:     2009-12-11 15:52:43 -0800 (Fri, 11 Dec 2009)
      Log Message:
      -Added metadata so that resizeMode code hints. Needed to add the same metadata to Group since it doesn't inherit the enumerations from GroupBase. Renamed NOSCALE to NO_SCALE, which is more in line with naming conventions.
      -Added null checks in VScrollBar and HScrollBar in pointToValue().
      -Cleaned up VSlider's code.
      QE notes: No
      Doc notes: No
      Bugs: SDK-24627, SDK-24628
      Reviewer: Ryan
      Tests run: checkintests
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24627
          http://bugs.adobe.com/jira/browse/SDK-24628
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Group.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/HScrollBar.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/ResizeMode.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/VScrollBar.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/VSlider.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/GroupBase.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/core/SpriteVisualElement.as
