0 Replies Latest reply on Dec 11, 2009 11:19 PM by HansMuller
    [svn:fx-trunk] 12879: Revised the way dataProvider CollecitonChangeEvent reset/ refresh events are handled, and likewise for changes to the
    HansMuller Level 1
      Revision: 12879
      Revision: 12879
      Author:   hmuller@adobe.com
      Date:     2009-12-11 23:19:33 -0800 (Fri, 11 Dec 2009)
      Log Message:
      Revised the way dataProvider CollecitonChangeEvent reset/refresh events are handled, and likewise for changes to the
      itemRenderer, itemRendererFunction, and layout.useVirtualLayout.    The overall goal was to reuse existing item renderers
      when only the dataProvider changed, layout.useVirtalLayout == true, itemRendererFunction == null, itemRenderer != null.
      We no longer eagerly remove all renderers when the aforementioned property/event changes occur, and then only do so
      at commitProperties() time if they can't be reused.
      Also: the undocumented protected DataGroup/cleanupDataProvider() method is now private and is called removeAllItemRenderers().
      QE notes:
      Doc notes:
      Bugs: sdk-23228
      Reviewer:
      Tests run: DataGroup, List
      Is noteworthy for integration: no
      Ticket Links:
          http://bugs.adobe.com/jira/browse/sdk-23228
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/DataGroup.as
