0 Replies Latest reply on Dec 12, 2009 12:42 AM by Evtim Georgiev (Adobe)
    [svn:fx-trunk] 12880: Fix http://bugs.adobe.com/jira/browse/ SDK-23833 DragDrop of multiple items to Spark List is much slower than to Halo List
    Evtim Georgiev (Adobe) Level 2
      Revision: 12880
      Revision: 12880
      Author:   egeorgie@adobe.com
      Date:     2009-12-12 00:41:36 -0800 (Sat, 12 Dec 2009)
      Log Message:
      Fix http://bugs.adobe.com/jira/browse/SDK-23833 DragDrop of multiple items to Spark List is much slower than to Halo List
      Problems:
      1. The selection in the drag initiator was not getting properly cleared and it was causing n^2 operations for drag-moving n items.
      2. The selection in the drop target was not getting properly cleared before the dropped elements were inserted, which resulted in n*m operations for inserting n items with m already selected items.
      3. The LinearLayoutVector in the drop target was shifting cached sizes for each element inserted, resulting in m*n operations for dropping n items in front of m items.
      Note #3 is not a drag-and-drop specific problem, but a problem for insert/delete in all virtual layout cases (vertical/horizontal).
      Fixes:
      1. & 2. - properly clear the selection before the remove/insert operations, as the selection is going to be updated after the operations anyway.
      3. Modify the LinearLayoutVector to store insert/remove requests as pending intervals. The pending intervals get flushed before any size updates/reads are executed.
      QE notes: None
      Doc notes: None
      Bugs: SDK-23833
      Reviewer: Hans
      Tests run: checkintests, mustella tests/gumbo/, tests/DragManager
      Is noteworthy for integration: No
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/listClasses/ListBase.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/List.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/layouts/supportClasses/LinearLayoutVec tor.as
