0 Replies Latest reply on Dec 12, 2009 4:05 AM by Carol L. Frampton
    [svn:fx-trunk] 12882: TLF Build 570 (except their build.xml).
    Carol L. Frampton Level 2
      Revision: 12882
      Revision: 12882
      Author:   cframpto@adobe.com
      Date:     2009-12-12 04:05:00 -0800 (Sat, 12 Dec 2009)
      Log Message:
      Note the build.xml in textLayout currently doesn't build the default target ant main.  To build a debug textLayout.swc use ant clean main.
      Build 570
      • Fix SDK-24677 Major performance regression in flex 4 text area after 12650
      • Fix 2506177 Asserts when resizing the Argo window or Firefox window with Argo plug-in x385.
      • Fix 2506500 TextFlowTextLineFactory.createTextLines is loosing the swfContext when truncating
      QE notes:
      Doc notes:
      Bugs:
      Reviewer:
      Tests run: checkintests
      Is noteworthy for integration: no
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24677
      Modified Paths:
          flex/sdk/trunk/frameworks/air-config.xml
          flex/sdk/trunk/frameworks/flex-config.xml
          flex/sdk/trunk/frameworks/libs/textLayout.swc
          flex/sdk/trunk/frameworks/projects/textLayout/ReleaseNotes.txt
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.xml
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/BuildInfo.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/FlowComposerB ase.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/conversion/BaseTextLa youtImporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/FlowLeafElem ent.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/SpanElement. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/TextFlow.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/factory/TextFlowTextL ineFactory.as
          flex/sdk/trunk/frameworks/projects/textLayout/tlf.properties
      Added Paths:
          flex/sdk/trunk/frameworks/rsls/textLayout_1.0.0.570.swf
      Removed Paths:
          flex/sdk/trunk/frameworks/rsls/textLayout_1.0.0.569.swf
