• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
command line error with large codebase?
Engaged ,
Dec 12, 2009 Dec 12, 2009
any idea?
if i change the source to go down the code tree to say
-s "D:/wrk_gapp-i17/gariffCode/src/tinylion/gariff"
then all is fine
but all of the following give the same error
-s "D:/wrk_gapp-i17/gariffCode/src/tinylion/"
-s "D:/wrk_gapp-i17/gariffCode/src/"
is it the amount of files?
any source  that goes deeper is fine;
-s "D:/wrk_gapp-i17/gariffCode/src/tinylion/gariff/views"
-s "D:/wrk_gapp-i17/gariffCode/src/tinylion/library"
etc
as you can see ive tried uping the memory (same what ever value i use)
using latest version as far as i know
$ java -Xmx1024 -jar "A:/_tools/flexPMD/flex-pmd-command-line-1.0.jar" -s "D:/wrk_gapp-i17/gariffCode/" -o "D:/wrk_gapp-i17/gariffCode/_pmdOut/all_flex/" -r "A:/_tools/flexPMD/all_flex.xml"
12-Dec-2009 21:34:09 com.adobe.ac.pmd.engines.AbstractFlexPmdEngine loadRuleset
INFO: Ruleset: A:\_tools\flexPMD\all_flex.xml
INFO: Rules number in the ruleSet: 82
Exception in thread "main" java.lang.IndexOutOfBoundsException: Index: 1, Size: 1
        at java.util.ArrayList.RangeCheck(Unknown Source)
        at java.util.ArrayList.set(Unknown Source)
        at com.adobe.ac.pmd.files.impl.MxmlFile.copyScriptLinesKeepingOriginalLineIndices(MxmlFile.java:131)
        at com.adobe.ac.pmd.files.impl.MxmlFile.extractScriptBlock(MxmlFile.java:162)
        at com.adobe.ac.pmd.files.impl.MxmlFile.<init>(MxmlFile.java:55)
        at com.adobe.ac.pmd.files.impl.FileUtils.create(FileUtils.java:83)
        at com.adobe.ac.pmd.files.impl.FileUtils.computeFilesList(FileUtils.java:58)
        at com.adobe.ac.pmd.FlexPmdViolations.computeFiles(FlexPmdViolations.java:131)
        at com.adobe.ac.pmd.FlexPmdViolations.computeViolations(FlexPmdViolations.java:94)
        at com.adobe.ac.pmd.engines.AbstractFlexPmdEngine.computeViolations(AbstractFlexPmdEngine.java:156)
        at com.adobe.ac.pmd.engines.AbstractFlexPmdEngine.executeReport(AbstractFlexPmdEngine.java:138)
        at com.adobe.ac.pmd.commandline.FlexPMD.startFlexPMD(FlexPMD.java:115)
        at com.adobe.ac.pmd.commandline.FlexPMD.main(FlexPMD.java:69)
TOPICS
FlexPMD
Views
791
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee , Dec 14, 2009 Dec 14, 2009
You have somewhere in your code base, a MXML file which leads to this exception. It would great if you could try to identify this one.
You would then be able to add to the test suite to avoid regressions.
Xavier
Votes
Translate
Translate
Adobe Employee ,
Dec 13, 2009 Dec 13, 2009
From your stacktrace, it is not related to the size of the project.
Can you open a bug in JIRA with the stacktrace, please?
Xavier
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Xavier
Votes
Translate
Translate
Report
Report
Engaged ,
Hi again
now I know where to start looking I'm positive i can track this one down for yo9u this evening.
i'll get back to you later
cheers
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Dec 15, 2009 Dec 15, 2009
LATEST
Great Glenn !
Votes
Translate
Translate
Report
Report
