2 Replies Latest reply on Dec 12, 2009 5:40 PM by laxmidi
    Achtung Nerdlings, Need Help with Error 1061
    laxmidi Level 1
      I can't figure out why I'm getting the following error:
           1061: Call to a possibly undefined method getAdReturn through a reference with a static type Class
      Any suggestions?
      I've highlighted the line on which I get the error:
      import flash.net.navigateToURL;
      import com.joeblow.ads.Ad;
      import com. joeblow.ads.OpenAds;
      private var _adReturn:Ad;
      private function initAd():void {
      _adReturn = OpenAds.getAdReturn();
      adImage.source = _adReturn.mediaSource;
      adImage.buttonMode = true;
      adImage.addEventListener(MouseEvent.CLICK, sendToURL);
      The class is as follows:
      package com.joeblow.ads
      import flash.external.ExternalInterface;
      import mx.controls.Alert;
      public class OpenAds {
      private static var externalCallback:String = "callOpenAds";
      private static var retries:uint = 10;
      public function OpenAds(){
      public function getAdReturn():Ad {
      var xmlReturn:XML;
      if(ExternalInterface.available) {
      var adReturn:String = ExternalInterface.call(externalCallback);
      try
      adReturn = adReturn.replace("//]]>->","//]]>->\n");
      var infoTagsIndex:int = adReturn.indexOf('<script type="text/javascript" src=""', 0);
      adReturn = adReturn.substring(infoTagsIndex, adReturn.length);
      var wasFlash:Boolean = false;
      if(adReturn.search("<embed") == -1) {
      adReturn = adReturn.replace('></a>', '></img></a>');
      adReturn = adReturn.replace('></div>', '></img></div>');
      else {
      adReturn = adReturn.replace('></div>\n<script','></embed></div>\n<script');
      adReturn = adReturn.replace('></div>\n<noscript','></img></div>\n<noscript');
      wasFlash = true;
      adReturn = '<adXMLReturn>' + adReturn + '</adXMLReturn>';
      xmlReturn = new XML(adReturn);
      var ad:Ad;
      if(wasFlash){
      ad = new Ad(xmlReturn, true);
      else {
      ad = new Ad(xmlReturn);
      catch(error:Error){
      Alert.show(error.message + 'stacktrace:' + error.getStackTrace(), "Error");
      else {
      Alert.show("Javascript must be enabled to view this page properly.", "Javascript Not Detected");
      xmlReturn = new XML('<root>xml</root>');
      return ad;
      If you can help me, I'd really appreciate it!!
      -Laxmidi
