0 Replies Latest reply on Dec 12, 2009 3:54 PM by deepa subramaniam (adobe)
    [svn:fx-trunk] 12883: Remove the skin classes from the halo theme project to avoid redundancy with the airframework /framework swcs.
    deepa subramaniam (adobe) Level 2
      Revision: 12883
      Revision: 12883
      Author:   dsubrama@adobe.com
      Date:     2009-12-12 15:53:50 -0800 (Sat, 12 Dec 2009)
      Log Message:
      Remove the skin classes from the halo theme project to avoid redundancy with the airframework/framework swcs.
      QE notes: No
      Doc notes: No
      Bugs: SDK-24293
      Reviewer: Glenn
      Tests run: Checkintests, smattering of Halo and AIR mustella tests
      Is noteworthy for integration: Yes
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24293
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/FrameworkClasses.as
          flex/sdk/trunk/frameworks/projects/halo/build.xml
      Added Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/WindowBackground.as
      Removed Paths:
          flex/sdk/trunk/frameworks/projects/halo/assets/
          flex/sdk/trunk/frameworks/projects/halo/src/HaloClasses.as
          flex/sdk/trunk/frameworks/projects/halo/src/mx/skins/
