1 Reply Latest reply on Dec 13, 2009 1:33 AM by Mylenium
    how to remove pluggin? error/virus?
    hkahil_1982
      hi pple
      i have a big probleme please i need help
      i can't work anymore on after effect cause i have installe a pluggin called :
      CyberZeka TVzeka Frame Buffer 1.0.8
      and i didnt like it so  i delete the folder and now i have a error message says:
      REGISTRY PROBLEM
      "Registry entry stat not found.
      please run TVzeka config".
      so i would like to remove this pluggin from the registry how can i do , cause this window is showing up at every moment
      when i work on after effect please help
      thanks
        • 1. Re: how to remove pluggin? error/virus?
          No idea. Never used it and it has been deprecated for several years now. I would think that you can remove the offending registry entries simply by running regedit. What's strange, though, is that the warning comes up in the first place, so most definitely there are still some remnants of it somewhere. Maybe a DLL in the AE directory or some data in the AE prefs. In the latter case, simply deleting the prefs and letting AE create new ones would probably solve the problem...
          Mylenium
