0 Replies Latest reply on Dec 12, 2009 8:07 PM by Darrell Loverin
    [svn:fx-trunk] 12887: Add asset files to the link checksum and OEMReport timestamps.
    Darrell Loverin Level 4
      Revision: 12887
      Revision: 12887
      Author:   dloverin@adobe.com
      Date:     2009-12-12 20:06:41 -0800 (Sat, 12 Dec 2009)
      Log Message:
      compiler/src/java/flex2/compiler/config/ConfigurationBuffer.java
      Add calculateLinkChecksum() so the OEM API can add archive files to the link checksum.
      compiler/src/java/flex2/tools/CompcConfiguration.java
      Add getIncludeFileInfo() so files specified using the -include-file option are added to the link checksum.
      compiler/src/java/flex2/tools/oem/internal/OEMReport.java
      Add archive files to the timestamps.
      compiler/src/java/flex2/tools/oem/Library.java
      Add archive files to the link checksum.
      QE notes: None.
      Doc notes: None.
      Bugs: SDK-24622
      Reviewer: Peter
      Tests run: checkintests
      Is noteworthy for integration: no
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24622
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationBuffer.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/CompcConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Library.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/OEMReport.java
