0 Replies Latest reply on Dec 14, 2009 7:12 AM by Carol L. Frampton
    [svn:fx-trunk] 12901: Removed get/ set fontContext and replaced getEmbeddedFontContext() with the same code that is in RichEditableText?\226?\128? \153s getEmbeddedFontContext().
    Carol L. Frampton Level 2
      Revision: 12901
      Revision: 12901
      Author:   cframpto@adobe.com
      Date:     2009-12-14 07:11:55 -0800 (Mon, 14 Dec 2009)
      Log Message:
      Removed get/set fontContext and replaced getEmbeddedFontContext() with the same code that is in RichEditableText?\226?\128?\153s getEmbeddedFontContext().  Since they are all UIComponents they should all work the same way now.
      QE notes: gumbo/components/Label/Properties/Label_Properties_tester1 test is obsolete and should be removed because Label no longer has a fontContext property
      Doc notes:
      Bugs:
      Reviewer: Alex
      Tests run: checkintests, Label, RichText
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/TextBase.as
