0 Replies Latest reply on Dec 14, 2009 7:21 AM by Carol L. Frampton
    [svn:fx-trunk] 12902: TLF Build 571 (except their build.xml).
    Carol L. Frampton Level 2
      Revision: 12902
      Revision: 12902
      Author:   cframpto@adobe.com
      Date:     2009-12-14 07:21:02 -0800 (Mon, 14 Dec 2009)
      Log Message:
      Note the build.xml in textLayout currently doesn't build the default target ant main.  To build a debug textLayout.swc use ant clean main.
      Build 571
      • Adding default tab stops for players before Argo that will apply if the tabStops in the TextBlock would otherwise be null. Fixes 2505894.
      And not in the release notes but corrected
          FlowElement.initialize -> initialized
      QE notes:
      Doc notes:
      Bugs:
      Reviewer:
      Tests run: checkintests
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/trunk/frameworks/air-config.xml
          flex/sdk/trunk/frameworks/flex-config.xml
          flex/sdk/trunk/frameworks/libs/textLayout.swc
          flex/sdk/trunk/frameworks/projects/textLayout/ReleaseNotes.txt
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.elemen ts.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.xml
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/BuildInfo.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/FlowElement. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/GlobalSettin gs.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/ParagraphEle ment.as
      Added Paths:
          flex/sdk/trunk/frameworks/rsls/textLayout_1.0.0.571.swf
      Removed Paths:
          flex/sdk/trunk/frameworks/rsls/textLayout_1.0.0.570.swf
