0 Replies Latest reply on Dec 14, 2009 7:54 AM by Chet Haase
    [svn:fx-trunk] 12903: Fix for regression in BitmapUtil.getSnapshot().
    Chet Haase Level 3
      Revision: 12903
      Revision: 12903
      Author:   chaase@adobe.com
      Date:     2009-12-14 07:53:53 -0800 (Mon, 14 Dec 2009)
      Log Message:
      Fix for regression in BitmapUtil.getSnapshot(). The fix last week (for sdk-20250) compensated for larger bounds with text objects and objects whose children have filters that go beyond the parent bounds. But the new call to BitmapData.getColorBoundsRect() had an error in the mask value that resulted in only capturing colored pixels, not all opaque pixels. This fix uses a mask that will cause the function to correctly capture all opaque pixels, regardless of color.
      QE notes: failure in Mustella Wipe_FxAnimateColor, but this is a known intermittent failure, not related to this fix
      Doc notes:
      Bugs: sdk-24684
      Reviewer: SteveB
      Tests run: checkintests, Mustella spark/effects/Wipe|CrossFade|AnimateShaderTransition
      Is noteworthy for integration: yes
      Ticket Links:
          http://bugs.adobe.com/jira/browse/sdk-20250
          http://bugs.adobe.com/jira/browse/sdk-24684
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/utils/BitmapUtil.as
