0 Replies Latest reply on Dec 14, 2009 9:43 AM by jmurphy67
    [svn:fx-trunk] 12905: -fix the textLayout bundle target to use the correct playerglobal version so that it builds correctly .
    jmurphy67 Level 1
      Revision: 12905
      Revision: 12905
      Author:   jimurphy@adobe.com
      Date:     2009-12-14 09:42:47 -0800 (Mon, 14 Dec 2009)
      Log Message:
      -fix the textLayout bundle target to use the correct playerglobal version so that it builds correctly.  I have also turn the building of this rb back on.
      -add the building of bundle and fat-swc to flash-integration; also added bundles/en_US directory with empty.properties
      QE notes: no
      Doc notes:
      Bugs: no
      Reviewer:
      Tests run: checkintests
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/trunk/frameworks/build.xml
          flex/sdk/trunk/frameworks/projects/datavisualization/build.xml
          flex/sdk/trunk/frameworks/projects/flash-integration/build.xml
          flex/sdk/trunk/frameworks/projects/textLayout/build.xml
      Added Paths:
          flex/sdk/trunk/frameworks/projects/flash-integration/bundles/
          flex/sdk/trunk/frameworks/projects/flash-integration/bundles/en_US/
          flex/sdk/trunk/frameworks/projects/flash-integration/bundles/en_US/empty.properties
