4 Replies Latest reply on Dec 14, 2009 11:52 AM by gdas@nsol
    Type conversion placeholder?
    gdas@nsol
      Is it possible to define a variable as one type and later change it to another type?
      What I would like to achieve is a variable that I can cast to different components that all use the IVisualElement class. So the variable exists in a component and later the type is changed inside a funcion. I tried with the "as" operater and the old-fashioned casting with (), but without results. Is there something like a placeholder for the type? Or am I thinking the wrong way?
      Here a short example of what may be the code:
      private var multiType:IVisualElement;
      private function init(type:String):void
           switch(type)
                case "myComponent":
                     multiType = new MyComponent();
                break;
      So the idea is that the variable 'multiType' which is of type 'IVisualElement' is changed to type 'MyComponent'.
      Thank you for any help.
        • 1. Re: Type conversion placeholder?
          msakrejda Level 4
          To do something like that, you'd need to declare the multiType variable as Object or * and simply forgo type-checking. It's a little bit of a cop-out, but it's not clear what you're trying to do at a higher level--there may or may not be better ways to go about it.
          • 2. Re: Type conversion placeholder?
            gdas@nsol Level 1
            The * type worked fine. I didn't know that that type existed.
            Thank you very much.
            • 3. Re: Type conversion placeholder?
              msakrejda Level 4
              Object should have worked as well, since it's dynamic. Perhaps
              FlexBuilder doesn't like it--it's not terribly smart sometimes. * is
              just like Object, except that it can also hold the value undefined (of
              the type void). I.e., the type hierarchy looks something like
                Object    void (with the one possible value of undefined, like
              Boolean only holds true and false)
              (all the usual classes)
              • 4. Re: Type conversion placeholder?
                gdas@nsol Level 1
                The type 'Object' results in the following error message:
                1118: Implicit coercion of a value with static type Object to a possibly unrelated type mx.core:IVisualElement.
                I also tried to use IVisualElement as initial type but I did not succeed in casting it to another type (eg: MyComponent) to make all the variables and functions accessible from MyComponent.
